Need this stuff gone. So make some offers.
Greddy plenum,
80mm hypertune throttlebody,
Custom twin feed fuel rail suit top feeds
HKS bov
$1800 for the lot
6boost manifold, $1100
Garrett T51r turbo with 4" dump pipe and filter $2800
turbosmart 60mm gate $900
Ported RB25 head with Tomei cams, cam gears, polished cam covers and splitfire coils (Needs clearances checked)
offers...
https://www.sau.com.au/forums/topic/264610-rb25-parts/
  • 3 weeks later...
Need this stuff gone as doesnt fit on a 26. So make some offers.
Greddy plenum,
HKS bov
$1300 for the lot
Garrett T51r turbo with 4" dump pipe and filter $2600
Ported RB25 head with Tomei cams, cam gears, polished cam covers (Needs clearances checked)
offers...
https://www.sau.com.au/forums/topic/264610-rb25-parts/#findComment-4559140
  • 1 month later...
what sort of condtion is the ported RB25 head with Tomei cams, cam gears, polished cam covers and splitfire coils how many km's and how old
The head has been on the 3lt for about 3hrs driving.
Im keeping the coils for the 26 head.
https://www.sau.com.au/forums/topic/264610-rb25-parts/#findComment-4672559
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
