hello, i have a r32 gtst with a problem that is driving me insane
lately it has been bouncing of 2500 revs and wont go any higher, as well when this happens it idols really high
when i drive the car in the morning it is fine but once the car seems to heat up, it idols shit and does the same thing. this also occurs if i drive the car then turn it off and leave for around minimum of 15 min and then i start it up again
sometimes if i drive it at a constant speed it seems to go away
i just got a NEW air flow meter, TPS and oxygen sensor, and got dyno'd. All this work was performed by Dynomotive in bayswater, Vic
it was fine when i drove it away and for about 30 min but then i turned the car off and waited around 15 min, then started it back up, it did the same thing for a few k's then stopped doin it
i have noticed a black wire on the air flow meter wiring harness is a bit stripped, would this contribute to it?
any reason why it does it when its hot?
PLEASE HELP !!!!!!!
https://www.sau.com.au/forums/topic/264626-rb20-bounces-2500-revs/
    • Holy hell! That is absolutely stunning! Great work!!!
