First R35 To Get The Ricer Treatment
funkymonkey
 Share
  • Replies 60
if it didn't have the gay airbrushed graphics, doors and bonnet opened normally, the wheels were black and no neons... it could have been a nice car.
i dont mind the interior that much but it would have looked better with black suede and pearl black speaker surrounds.
if it was mine it would be half stripped, caged, black on black with cf bits everywhere and a helmet in place of a missing passenger seat :P
What's wrong with it...looks nice...not too over done...very tasteful.
If it has glowing neon lights under it at night that would be the perfect final touches......perfect for cruising through Punchbowl on a Friday night.
f*k LAMBO DOORS
that car could have been sooooo much nicer
blue is such a shit colour IMO
piss of the lambo doors and the f**ked up bonnet
if you really wanted to build a show car with it
keep it looking classy brandy wine kandy with some dished rims (matte black centre with body coloured dish) and all the painted and trimmed bits inside black
OMG I HATE BLUE SO MUCH
Bloody yanks...I new this was going to happen :yes: For Jeebus sake, pull your pants up, put your hat on straight, stop flashing gang signs and leave the R35 alone you pack of arse hats
HA HA HA HA!! MAGNIFICENT WORK. couldn't have said it better myself! that riced GT-R is completely F***D
This thread should have had a bucket warning..
How to f**kup a perfectly balanced and engineered car, it looks like one of those toy dub city cars I buy for my nephew.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
