First R35 To Get The Ricer Treatment
funkymonkey
 Share
check out the Top secret prototype pic of R35 and convertible R35
Love what the boys can do these days with photoshop.
Amazing how UGLY as shit that R35 looks in convertible, not surprisingly though the R35 wasn't exactly designed to be the most beautiful of beast's :-)
Although I love how my R35 looks and wouldn't change a thing, its Jap Muscle, not designed to look good in soft top.
  • Replies 60
Just discovered this thread, damn, that is so gay. I want you to picture yourself as an R35 sitting in a showroom. Now a slimy lookin' turd burgler walks in with gangster basketball singlet, track pants, Nike air runners, gold ring on every finger and, yeah, you guessed it, gold tooth caps to work in beautifully with his gold necklace carrying a large clock.
He says to the dealer, "yo' my brother, sup' wit' dat'". Dealer says, "That'll cost ya' a half kilo blood". They get down an' do dat' shit.
Right about now poor R35 is saying, "Noooooooooooooooooooooooooooooo".
Think about it, would you like your arms hacked off and made to work backwards ? How would you like it if someone sliced off your man appendage and sewed it back on above your poop chute ? Then they paint you up like a Smurf and make you parade around in public. Blasphemy !
Love the dish though, yeah, gives me wood. :banana:
You were still saying they were cool 3 days ago when we were in their workshop looking at their actual R35 GTR. lol
The stickers on that photo chopped effort may be what it will look like if they speed run it, the rest mmmnah.
Top Secret make the worst coffee lol
  • 1 year later...
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
