^^^ How True! :yes:
THE IMPORTANT THING TO NOTE IS THAT THE ASSEMBLY POINT IS NOW...
"SYDNEY INTERNATIONAL REGATTA CENTRE" 9.30-10.30am
Old Castlereagh Road at Castlereagh ie North Penrith
great brochure.
I am concerned nobody will have a chance at winning those award categories so, can we add..
"Information Overload" awarded to the cockpit that looks most like a flight deck
"Auto Wash King" awarded to the car with the most visible cobweb scratching
"Pimpin aint easy" awarded to anything with 20" wheels, spinners, etc
"Bozozuko master" awarded to anything, well, Bozozuko
"Most incomprehensible ICE" awarded to the car with the most original JDM navi and stereo trinkets with no english language modes
"Least Likely To Idle" awarded to the car with the least stable idle
"Petroleum Liberation" awarded to the car pumping the most unburned fuel out the tail pipe (judged by number of seconds required to create actual tears)
"Defect King" awarded, by someone in cop fancy dress, to the car with the most clearly visible/audible defectable items
This way I feel that most attendees will believe they have a shot at at least one award on the day :yes:
well actually you deserve it too Nick.
...been told you've been whispering in the ears of Hills M/S, Powerplay, Croydon RD etc
It starts at Regatta ctr Penrith right? 9.30am right?
Are you thinking of coming Delta Force?
By all means just turn up, i'll add your name to the attendance list.
Check out the thread for any other details:
10th Anniversary R34 Cruise
^^^...maybe a tad less than 100 leaving Sydney International Regatta Ctr at Penrith
Congregating at around 9.30
Briefing at 10.15
ETD at 10.30
ETA Mt Wilson 12 Noon
Good to have you in your 'black beauty' Denis
ZOMG !#!$!$$ 100 ??? you serious ? Holy crapola batman .. I thought it's gonna be like 20 cars max. Man this thing will be massive ;) Can't wait!
I prefer to call 'her' The Reaper :D
great brochure.
This way I feel that most attendees will believe they have a shot at at least one award on the day :P
Hahaha, very good post!
Ill be going for the least likely to idle and the petrol liberation categories. Stand behind my car to see why.
great brochure.
Yeh I lmao ...
...but Skaifie won't sign 'em ! ! !
If weather is a bit drizzly, we're still "ON"
If it's rain, the Event will be delayed ONE week.
Wet weather up at Mt Wilson will mean that the Demonstration by Sensei Hans and Sensei Dave after lunch will be cancelled due to safety reasons. :D
On sunday cause i have to drive passed the mount wilson turn off on the way 2 pick nick up ill see wat the weather is doing on my way passed and let every1 know when i get down there or when i get coverage.
Please see attached. Any questions just post them up here. Print and bring it along with you if you wish.
cheers
Eugene
hi eugene i will be coming if it's not raining thanks bill (eat.430) blk 99 v spec
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
