  • Replies 42
ok i am starting to strip all the parts and just getting back to you all for your pm's thanks for being patient guys. my msn addy is [email protected] so if you guys want to add me on there that way i can get through what everyone has asked for thanks.
MY SKYLINE HAS BEEN DEEMED A REPAIRABLE WRITE OFF SO HERE LETS START SELLING OFF THE PARTS.
RB25 ENGINE $1100
RB25 MANUAL GEARBOX $1400
HKS HYPER D COIL OVER SUSPENSION $1000
3" EXHAUST WITH CANNON $500
BLITZ DUAL STAGE BOOST CONTROLLER W/ BLITZ TURBO TIMER $170
VAULT CRYSTAL 19" WHEELS NEW TYRES $1100
DL DASH DIALS with dash $450
FRONT WAS DAMAGED NO INTERCOOLER OR RADIATOR AND BACK WAS HIT BOOT IS DENTED IN.
STILL HAVE EVERYTHING ELSE ASWELL MAKE OFFERS
PRICE CHANGES
RB25 ENGINE $900
RB25 MANUAL GEARBOX $1300
HKS HYPER D COIL OVER SUSPENSION $900
3" EXHAUST WITH CANNON $350
BLITZ DUAL STAGE BOOST CONTROLLER W/ BLITZ TURBO TIMER $170 SOLD
VAULT CRYSTAL 19" WHEELS NEW TYRES $1000
DL DASH DIALS CLUSTER $130
DASH $150
LET ME KNOW GUYS
I HAVE INCLUDED SOME MORE PICS OF PARTS AND UPDATED LIST
RB25 ENGINE $900 SOLD
HKS HYPER D COIL OVER SUSPENSION $850
3" EXHAUST WITH CANNON $300
VAULT CRYSTAL 19" WHEELS NEW TYRES $950
DASH $150
Do you have the gear surround? If so how much and is the cigarrette lighter hole cut out?? Also if you have the handbrake and shift boot I may be after them depending on the condition. Cheers.
RB25 ENGINE $1100 SOLD
RB25 MANUAL GEARBOX $1400 SOLD
HKS HYPER D COIL OVER SUSPENSION $1000 SOLD
3" EXHAUST WITH CANNON $500 SOLD
VAULT CRYSTAL 19" WHEELS NEW TYRES $1100 SOLD
I ONLY HAVE STUFF LIKE BRAKES ROTORS HUBS SEATS GLASS DOORS LEFT OVER GUYS
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
