Strange about that one Trent, when i called up they said contact the mob up in QLD (which i assume is performance springs)
and said they dont deal with springs....
anyone specific i should speak to?
  • Replies 77
im about to test some camtech cams over the next few weeks, ive heard great feedback and im sure they are just profiled off popular grinds anyway...... I tried a few sets of crow SR cams awhile back and i wont go there again.... disaster.
as for valve springs for your rb or sr stay away from the ones you listed...... they soften up way to quick. Ive been burnt a few times now and since switching back to Ferrea / Brian Crower and the jap gear ive had ZERO issues. We used to use a lot of the performance springs in the v8's we built (big solid rollers) and even then they required swapping out more often than the us-of-a stuff. Then again thier the cheapest and most shops make good coin outta them....
Just out of interest from those who are using them have they had the springs tested after they were removed? i have some kelford ones here for a 26 im about to have tested (done one full season) it will be interesting to see how they fared.
are performance springs and PSI springs the same company?
have you used any of the supertech stuff trent?
marko, do you know what shim size was needed with the cams? i'm guessing its a pretty big one caus u didnt list aftermarket buckets... also what springs did u go for?
big revs on that setup & ur going to be tearing it down regularily to keep it alive
Camtech do a spring and titanium retainer set... might be worth a call? we have used 2JZ ($550rrp) and SR20 ($450rrp), im yet to use their RB kit so im not sure of the price.
when i spoke to malcolm from camtech about my cams, he recommended that i go via 'performance springs' for valve springs
he stated that these springs are best for the gtr - interesting feedback considering camtech actually sell their own springs as well
shims, buckets, retainers & valves were kept stock - no need to upgrade these bits on my head as recommended by pro engines
there will be no regular maintenance on my engine, remembering its an rb26/30 i wont need to rev it as hard as my rb26 BUT if i want to - it will be on tap :)
i just found out why... the Camtech SR20 titanium spring and retainer set i just received is actually BC gear (brian crower gear) :rofl:
Maybe all their jap valve train gear is just BC rebranded? i think the JZ stuff we used previous was very BC like too, and since BC does not make RB26 gear i reckon their solution is Performance springs... something i'm not happy to use..
Out of my league with big cams but what is being done with valve sizes , is it worth investigating oversize valves and slightly less aggressive cam profiles in RB26 heads ?
Just curious , cheers A .
very much so in my experience. but there is only room for 1mm oversize in the 26 head
That's what I'd herd as well , around 1mm . It doesn't sound like very much but being on the periphery of the valve means it probably makes a very real difference to how much gas can get past them with opened up or larger seats/throats .
It may be a case of larger valves with shortish high lift cams (provided the valves don't touch on the overlap phase) may work well .
Personal bent I suppose but I like the idea of really well modified heads and just barely enough cams to get the job done , probably because its difficult to get around cams that have gone too far duration and overlap wise .
Cheers A .
  • 1 year later...
dont forget my 26 was to be a drag engine, with 9200rpm limit... i had hks 272 with 10.2 lift... these cams would be well good to go to 9500rpm...
my 32 gtr has gibson group a cams, same as in the bathurst gtr's, i have -10 on that engine also, these cams will be a shitload better for drivability, thaink about it, if the bathurst gtr's used them they would have had one thing in mind, "torque" and still produced big numbers, and they were 26's not 30's, remember torque is what u want, if u focus on achiving this your car will be a animal....
Hi Mate
Can you please give me the gibson motorsport cam profiles as I would like to get kelford cams to grind me a set. . Your help would much appreciated. .
Edited by NZR32GT-R
Hi Mate
this is like asking colonel sanders for his secret kfc recipe - colonel probably didnt even know himself :P
LOL! ! you stated some specs on the first page of the thread.
Inlet 256 @ 9.5mm lift
Exhaust 278 @ 9.75mm lift
Where did you get this profile information from?
Also I am sure some one has a set of these cams & would be willing to share the profiles. .
I am realy interested in these cams as I have a set of group A turbos as well & I think these cams would suit them better than some Tomei Poncam Type Bs. .
Edited by NZR32GT-R
i am all for sharing info, although, i dont think anyone knows the real profiles of the cams, my post was only what i have heard (is it true though, not sure)
Kewl no problem yea I just wanted to confirm hopefuly some one will give up the secret :-D. .
but the profile you specified sounds like it should work well with group A turbos. .
How would you compare them to the Tomei's?
Tomei Specs:
Inlet 260 @ 9.15mm lift
Exhaust 260 @ 9.15mm lift
Is it better to run more duration on the RB26 as from what I have read the exhaust valves are realy small & only flow like 65% when compared to the inlet valves. .
Tomei Specs:
flow your head and cam it to suit the flow split, simple solution.
Just interested as to why?
Can anyone share their experience with the Lewis Engines valve springs? http://www.lewisengines.com.au/prod7.htm
I thought they use Performance Springs?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
