Trance Energy - Friday
R31Nismoid
 Share
yesterday was AWESOME!!
Got a bit cold towards the end - altho i was alot colder than most of my mates, probably cos i was sitting down.
We had the Premium tickets as my boss owns a share in ID&T who owns Trance Energy - so got to kick it in VIP the whole day which was awesome.
highlight of the day - i got to go up on MAIN STAGE AND ROCK IT with the DJ!!! Got up there right when he dropped Binary Binary ( ithink it was that song lol) and got a photo as well - will upload it when i transfer it across.
Ash, others that went, what did u guys think of it?
I'm a day festival virgin, have only been to a couple in the past, but i was pretty impressed with it once the sun went down. Looked a bit shaby during the day-time cos they used the carparks and not the grass areas.
Had a wicked day tho!
two words
f**kING AWESOME
mates started to feel the cold so left around 10ish
my favorite DJ's for the event was Sander Van Doorn and JUDGE JULES was freaking awesome
tried to look for Thark but f**k so many ppl lol
Was nuts - friend of mine was running a stage so I was lucky enough (and a few others) to get back there a few times during the day.
I'm still wrecked (had to be @ belgian beer by 12pm yesterday, so i officially cant move)... but a top top event.
you could possibly be talking about binary finary - 1999
tuff old school track. didnt hear it get played there, proberly wasnt at the main stage at the time
was suprised when bt played FLAMING JUNE.... 2 words, F***iNG ch0000000000n.
all in all top event.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
