  • Replies 45
Pretty sure Ace broke his legs over the past weekend, so you may be out of luck there. Pretty gay
ahh shit that sucks big time... im sure he could still do it from a wheelchair :)
Turbo rolla nice :)
put a hairdrier on your rolla too ;)
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4532164
For about $50 you could get a nice smallish intercooler to plumb into it. I couldn't stand running any forced induction without an intercooler. :P
i would for the awesomeness ... but its not the best idea
cos fuel vapor mixes from the carby into the induction system, one lil carby backfire could blow the front of the rolla a new a$$
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4539927
But thats more of a concern for a suck-thru system. Your blow-thru system could take the intercooler between the turbo and carby. :P
Edited by RubyRS4
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4540054
picked up those drift gauges from vince this arvo (boost, water temp and oil pressure) pretty keen to get em in the rolla.
they are pretty sexy n im tempted to put em in the 32 lol.
only reason i dont think i will is i currently have boost, water temp and oil temp... im not heaps keen on replacing my oil temp gauge with oil pressure.
wish me luck butchering the dash to get the gauges in lol
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4543426
Doesn't happen on blowthrough setups, 10yrs ago i had the same setup on a ke10
before going efi, the biggest problem you have with the stupid things is carby sealing
on hi-boost(16+psi), mine use to blow out carby gaskets all the time.
cheers
darren
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4543647
cheers
darren
it can happen, just far less likely than it is with draw through.. while the carby is backfiring I'm not even going to consider it lol.
I blew carb gaskets on the old carb that was only at 8psi too. the weber I have now should handle the 10psi I plan to run nicely
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4544017
I still have a custom fab plenum lying around for an L16, L18 or L20 motor! :thumbsup:
Might find a nice tidy auto 120Y, drop in an L20, Mahl pistons and Waggot cam and supercharge the dam thing with EFI. :)
Edited by RubyRS4
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4563160
I still have a custom fab plenum lying around for an L16, L18 or L20 motor! :D
Might find a nice tidy auto 120Y, drop in an L20, Mahl pistons and Waggot cam and supercharge the dam thing with EFI. :blush:
If you drop in an L16...using stanza struts as a brake upgrade, it will be a legal conversion... :sick: ...then blow it.....i miss my datto's....had 4 different ones back in the day
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4563191
If you drop in an L16...using stanza struts as a brake upgrade, it will be a legal conversion... :D ...then blow it.....i miss my datto's....had 4 different ones back in the day
I've had a total of 6 or 7 dattos over the years. Some of the most easy modded and fun cars ever. Parts interchangability is huge.
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4563248
    • Hell yeah. Glad to see it’s closer to the road.
    • Thanks Brad Sheriff. I think he single handedly made the price of NEO heads rocket to the stratosphere.
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
