Hi everyone,
I am trying to chase some longer wheel studs for the front of my 97 R33 Series 2 skyline but all the mainstream places I have tried (repco, sprints, etc.) either don't have them or can get them but it seems like an over inflated price ($10 per stud plus freight, i.e over $100 for the front wheels!).
Someone told me Wheelworx have them? If anyone knows of places please list them so I can give them a buzz and find out.
It would be a bonus if the place actually had some idea about performance cars as I did have a few questions as well.
Finally, I recall reading Nissan Patrol studs are suitable as they are longer but the correct width can anyone confirm this?
Any help would be appreciated!
Cheers
https://www.sau.com.au/forums/topic/264728-stockist-of-longer-wheel-studs/
Thanks everyone, I tried a few of the places initially listed (Motortraders and Adelaide tyre power, both these places didn't have them in stock).
Japanese Motorsport had Nismo 50mm and 60mm studs in stock so I got the front 10 in the 60mm length for $99 (this was the best price I got quoted, probably because they actually had them in stock and weren't a special order?!).
Thanks for your help.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
