I'd go 1000's, straight up.
i would buddy but theres like a 500bux differnece in price, bitch of a cold start and exhaust idle. =[
Would 1000cc Sards be ok to Run a 26/30 on E85 pushing 400-500kw?
Sorry to hijack
theyd be fine, only reason im asking is maybe they might be to overkill.
Edited by VB-
I went with 750's and now looking at having to move them on for something bigger - given hindshight I would have saved money if I'd gone 1000's first time around.
What ecu are you using to be concerned about injector control?
well ive always planned to use the PFC D jetro.......but some have raised the question about Haltech.....problem is i dont think they have a plug and play unit =[
I would go 1000cc, low impedance. Trying to make motor with 1000cc, high impedance, injectors idle would be an absolute prick.
The reaction time of a low impedance injector is a lot faster, hence the motor will idle more smoothly, than if you were to use a high impedance injector.
im in the same boat, in the sard range there are 2 options:
1. black top/orange tip, lag time 1m/s
2. light blue top/green tip, lag time .85m/s
is the 1st injector low impedence you are referring to?
i run 1000cc sards and bigger cams than mentioned and idle is no problem at all. cold start idle was never the greatest but i aint running the idle air control valve any more and never really cared as it wasnt a daily driver. I had to keep the revs up a touch for 30 secs and then it idled itself fine, dont think this is the injectors fault though.
1000's in a 14mm fuel rail. 1600's if you want to run e85. i have 1000's and at 376kw they are on 75-80% cheaper to get 1 set not having to buy smaller ones only to run out of RELIABLE headroom..
1000's idle perfect, just depends on your tune,, oh and ecu
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
