Long story short, I replaced the motor (rb25det in an r33) with another stock standard one.
Now the new motor had a different coil setup which didnt match the existing loom, so I put the old coils on and it all seems to be plugged in as before.
When cranking i get no spark in the plugs.
There is only one plug which I am mistified about, and that is one coming from the power box on the drivers side of the car. It has 2 prongs in it. I cant for the life of me find the matching plug, and I cant remember if it was previously plugged in.
Spark was perfect before motor change.
Can anyone let me know any suggestions on where to look? Or what tests(with a multimeter) can I do to narrow it down?
Thanks Heaps!! Once its runnin, im driving it off a cliff for a bit of revenge.
What year is your car and what year motor went into it?
series one have an external ignitor (grey box on top of the valley cover), series two have an internal ignitor on the actual coil.
Cheers,
Johno
Cheers,
Johno
Hi mate thanks alot for the reply. Its a S2 motor going into a S1 r33, but I used all the S1 accessories/loom.. etc.
Anyways, i got it running it turned out i didnt have the CAS clipped in fully... BUT...
Start it, runs for about 30 seconds, starts sounding chattery, black smoke out the exhaust, revs fluctuating.......
Turn it off, pull the dipstick and its coffee white in colour, with water leaking out of the exhaust.. I cant win my last motor blew whilst my mother was driving it at about 60km/h, and now ive spent 2 days installing this one to find out it has a blown head gasket/cracked block... who knows im over it.
So now Im out of options.
How much is it for a shop to fix a head gasket? shave the head and all that??
Headgasket, or cracked block or cracked head.
For what its worth maybe find another motor.
Yeah. Well to his credit the seller has been very co-operative and decided to give a full refund (Within half an hour of emailing him). Just means I have to take it back out again but given the situation i am a little more relieved.
I have a rebuilt bottom end which i was practically given but i didnt really want to go the rebuild stage with the gaskets and all that as I just want a reliable car again... But since I have probably halved the time of removing and replacing an rb25det motor due to experience, I may give it a go :D :D
The old head that was on the blown motor I still have, so I may get that crack tested and skimmed or whatever it needs.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
