hi guys, just wondering what size wheels and tyres most of you guys are running coz my 32 gtst only has 215-45-17 size tyres and they are scraping on the gaurds when i go over a decent sized bump at 80ks or more...(and when im turning at high speeds or braking hard). Have you guys had to roll your gaurds to stop this or is my car just bein a woman?
Any insight would be much appreciated. Thanks guys.
Leigh
https://www.sau.com.au/forums/topic/264816-r32-front-tyres-scraping/
Not very helpful Paul, i think he is aware this is a V35 forum, maybe he just wanted to get an idea of what tyres we roll with our V's.
With that, i will have to check mine for you later on if you wanted to get an exact size.
it will probably be different story with the R32 because we V owners seem to run with with bigger size than the 32s. so i suggest ask the fellow SAUers on your state aswell.
Sorry Sir-black32 :D
Sorry about this but I am not sure that Paul was being rude, but he does have a point and without trying to be 'unhelpful' it would be better if Sir-black32 asked this question where people with R32's frequent.
Specifically but rheotorically, how does a V35, equate to an R32 with our without rolled guards?
Rolling a V35 guard for a Tyre to Guard mount problem will not be the same as rolling the guard for a R32, even 'if' it had the same size wheel and tyre on it.
To mention my R33 Gts-t... someone had fitted GTR front Shocks to it when I bought it so it used to run out of travel on high speed corners with bumps, never hit the guard though only the inner plastic guard. If you didn't know the GTR front shock is about 40mm shorter than the RWD only GTS-T.
Some things to consider if I am trying to be helpful.
Do you have the correct size tyre for the rim?
Do you have the correct size wheel/tyre assembly for the car?
Is your ride height appropriate, ie more than 100mm minimum?
Are you front springs too soft?
Are you front shocks too short - see above?
Are you front shocks out of oil?
Are your front shocks leaking?
Sorry guys, didn't realise id posted in the v series area.... Had a few windows open at the time. obvisouly posted in the wrong place.
But while im here i might as well fill in a few details.
According to the plaqard the car came stock with 205/55/16, so upgrading to 215/45/17 is legal and "shouldn't" have any clearance issues.
The car is at standard ride hight.
My front springs aren't soft, nor do they appear to be leaking or out of oil.
Thanks for the suggestions tho guys.
Big problem here, you need to go back to the shop and throw the new set-up at them.
You tyre and wheel combo is now bigger diameter (9mm) and your speedo and gearing will have changed... the difference is not a lot but it may be why your tyres are scraping the guards.
Profile =
Old tyre 205/55/16 - 55% of 205mm wide = 112.75mm
New tyre 215/45/17 - 45% of 215mm wide = 96.75mm
Plus Wheel diameter
Old 16" = 406.4mm
New 17" = 431.8mm
= a total diameter of
Old 519.15mm
New 528.55
Regardless of the tread on the specific tyre you now have a larger set-up.
If you check different tyres (Brand and Type) in the same size the rolling diameter will nearly always be different, so if you have a 'larger' tyre this will add to your problems.
The new tyre is not the right size.
However at standard height, I doubt this should be a concern. Something still may be amiss.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
