Ok, so at some stage I was thinking of doing a plenum on the 34. There are a few problems that need to be accounted for and anyone with experiance to help out a bit.
My car is an auto so currently I run Nistune computer.
Unfortuently the nistune cant compinsate for the loss of the traction controll unit after the Throttlebody so it locks the car into third. Which means I cant replace the plenum. Enless I want to go down the road of a stand alone ECU, shift kit etc etc.
Is there anyway you can keep the traction control + installing aftermarket plenum... possibley a custom setup? Im looking at going a hi mount plenum, smaller body with longer runners as to avoid loosing response.
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/
Hey mate, i've got maunel GTT with a Plazmanan plenum running R33 S2 TB, my engine light stays on because the the factory R34 TB has two sensor, one for TPS and one for the ECU and the R33 one don't.
What power are you aiming? Coz there's no point having traction control when you have a 280rwk+ car lol
Think there are ways around it, i'e Greedy makes a kit for it i'm pretty sure.
Or alternately just take the bulbs out :D
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4525935
ive been told by a forum trader that greedy dont make the plenum for r34.
ull have to go plazmaman or something else (however the plazmaman ones r quite nice im going to be getting one shortly)
unfortunately no.....greddy dont make it for the ER34. but to be honest the plazmaman plenums seem to be quite amazing. supports over 1000hp, gets rid of all the ugly shit in the engine. and they claim it will increase throttle response by 20hp throughout the revrange. the best thing about plazmaman plenums is they keep the factory long runners so your response is always there.
my mate has had it on his r34 rb25/30 setup for about 6months now but his moving to a rb26 head and selling the plenum.
pretty cheap check it if your interested.
http://www.gtroc.com.au/forums/index.php?s...t&p=5015964
Edited by VB-
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4526194
plazmaman plenums on the NEO are a pain in the ass to fit
and after all the drama they still do do anything for TCS
which is why im in the process of making something so the ECU thinks everything is still stock with regards to TCS
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4526384
thanks for showing me that.
hopefully he still has the plenum next week when i get paid
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4526396
its not that simple
if you plug in the second TPS (one for the TCS) the car will not rev unless its seeing a full open signal
then the TCS mechanism is the size of two coke cans joined together where you gonna fit that?
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4526573
its not that simple
thats right, even after being in contact with the blokes from nistune there response was that they havent written anything into there chips yet to compinsate for the loss of TCS so automatically from there tests on the neo the Nistune locks the car into third without the TCS unit there. My answer has mostly been answered, as I havent seen many if any posts regarding this I was curious to see if any manafacturer had created a plenum or TB with supporting attachments for the TCS unit. Smartest thing I could think of would be to custom make a fitting for the unit on an aftermarket plenum. As you understand to simply remove the TCS unit for an automatic car would also mean Id hafto change to a stand alone ECU which would mean aftermarket shift kit... your already looking at 4g plus for the sake of simply installing a front facing plenum. Let us know Dahtone when you have a product from your research and as im happy to try it out.
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4526685
who has done theis and what u doabout the error light?
no tps pluged in?
Buit a greddy one fits fine on a NEO, just have to use a non neo throttle body. remove the TCS mechanism from the r34 throttle boby and leave ot plugged into the loom so the ecu thinks it is still there.
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4527092
i think most poeple who get aftermarket plenums are already in the 300kw+ range. TCS isnt gonna do much for you. my mate just got it removed alltogether
and it cleans up alot of the ugly shit wires in the engine bay aswell.
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4527310
Im fine with removing the TCS, problem is it just cant BE removed on an auto. You need well over 3g of mods just to remove that TCS.
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4527880
I assume it would run on some kind of ground signal and would measure the amount of current sent through when its open/closed 50% 80% blah blah so why dont you just make a sender which matches the signal when its fully opened.
Just a guess.
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4528016
  • 3 months later...
how do u remove the tcs?
or to do that do u need after market throtle bodies, plenums, etc?
because im keen to get rid of my traction control all togeather
the only thing its good for is pissing me off when i forget to turn it off lol
thanks guys
https://www.sau.com.au/forums/topic/264833-rb25-neo-plenum/#findComment-4758509
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
