  • Replies 250
I had an awesome day. Thanks to the cool weather i was able to run 18psi all day and it didn't miss a beat :) Would of been good if there was a few skylines in my group, the non cams group had a crazy amount of cars in it, would have been hard to get a fast full lap. Think i might get a rear muffler put on before i go out again, although i did love the sound of the 26 with just a 3inch pipe :(
yeah the r8 copped it bad,
not overly sorry, he was being a knob on the track as well as the blue xr5 focus... pushing in through the inside on corners, i copped a bit of grass on the first hairpin thanks to him otherwise could have made contact.
at the end of the day was running mid - low 1.30's which im quite happy with having only approx 180-190kw and auto. definitely looking forward to the next one :(
Edited by SkyHi_33
hey dale what oil temps are safe.. i fear i may have boiled mine while out there... last session of the day i went out i went hammer and tongs and exceeded 135-140 deg it lost a shit load of power so i took it real easy. checked oil it seems ok but definatly going to change it
hey dale what oil temps are safe.. i fear i may have boiled mine while out there... last session of the day i went out i went hammer and tongs and exceeded 135-140 deg it lost a shit load of power so i took it real easy. checked oil it seems ok but defiantly going to change it
lol, yeah that's a bit hot ideally you don't want to go much hotter than 120 max and you really want it to be sitting around the 100 mark. I would be replacing it asap if i was you. But if it is any concellation that's the same temps that Andrew is getting with his, and it's something he'll be sorting out when he gets back. i have some ideas on how to fix it and the THRUST turbos wouldn;t be helping things being oil cooled but we'll wait and see what we can figure out with his. That's a good thing with the modern reg' the sessions are only 5 or 6 hot laps long so you can push as hard as you can and just as your temp are getting too hight the sessions finished.
Edited by D_Stirls
Hey guys great day anybody have any footage
unfortunately blew my turbo spat a bearing (ouch)
thanks to all the guys that drove really well on the day and no thanks to the blue cars we all know about
thanks to "banned" we had fun chasing each other around the track.
hopefully fix turbo soon so i can get back out there for august 1st
You were the only one pushing into the braking zone into turn 1, Seems those brakes did work well.
Pity there were so many moving chicanes out there, you and Ryan would have put down some decent times, although track did seem slow!!
Was funny as seeing my mate in his Saloon Car(AU Falcon) no respect for turn 1 at all...... :P
Yeah the blue commodore was driving very loose, he spun a couple times already before the crash so he really should have eased up a little especially when coming onto the straight towards a cement wall etc. Was great weather out there thankfully! Was good to meet a couple more guys from the forums especially "omsin" who I had fun chasing! I think my best time for the day was 1:23 on the new kuhmo KU36 (actually held up quite well).
Ryan
Your GTR is "BANNED" yeah? One of the quicker cars in the sessions!
I got a few pics and vids, but no laptop. Ill get them up as soon as i can.
rubbings racing :P
fools acting like puts others off attending. not everyone has $2 panels on their cars
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
