  • Replies 250
I should be good to go for this guys :D.
I havn't got an oil cooler so if the oil temp creeps i'll just pull off the track and let her cool down.
+ will be a good chance to finally put some usernames & avatars to faces.
anything else i need to make sure ive done on the rb25 before i head out? catch can, oil cooler etc? its only got basic bolt ons and boosted turbo...
I don't think so mate.
People keep in mind you are only out there for 15 minutes hard driving at a time, that's it, it's not a 24 hour endurance race.
Not to mention that while you're out there, if someone spins out they wave the yellow flags, and you gotta go slow anyway, and someone is BOUND to spin out every round.
So your car actually does not actually go through that much punishment. If you went flat out in the hills from bottom to top it's the same sort of thing.
The only noticeable thing on my car was the brake fade. Brakes were not useless or anything, but effectiveness vastly diminished, and that was after 3 rounds, the last of which I used the brakes the most.
Just to put your minds at ease, when that happened and I couldn't slow down enough for a turn, I just drove straight, off the track, over some soft and squishy sand. No damage, no harm.
You will be able to hear/feel if something doesn't feel right and you can come off he track and have a look see.
how did you mange to get hold of those forms Brendan
could you please direct me in that direction
see attachments
Mallala_Drift_Practice_Form_P1.pdf
Mallala_Drift_Practice_Form_P2.pdf
Moodles please let me know of the gearbox flush sorts out the crunching issue, I know a guy who has complained of the same thing, you think the gearbox flush will sort it out?
on the track 3rd to 4th is normal to crunch on 32 gtrs (ive been told it will crunch no matter what gearbox fluid you have in there), just delay the shift an extra second and it wont crunch.. as for other crunches with other gears, good quality gearbox oil should help (shaun at boostworx has recommended to me redline's shockproof).
As for shift light, looking at a simple one, have my eye on the Gizzmo DSII (http://www.modyourcar.com.au/gizzmo-dsii-shiftlight-p5650)
paid off my seat this evening, ill be out there if i get that fitted in time. dont wanna spend my time out on the track driving like a habib cause i cant sit in a normal position with a helmet on...
Im looking at getting one of these shift lights, its not cheap but i think it better than just a single light. http://www.tunersgroup.com/Online_Store/Sh...ght_System.html
driving like that will improve your lap times by about 5 seconds there Dave
That shit light Chad is awesome mate
similar to what the F1 cars have
Edited by Krishy
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
