So today I decided I'd service my car, and having never changed the spark plugs, I thought I'd be able to figure it out no problem, then I realised... I had another thing coming...
I drive a 33 GTST and... Are the Spark Plugs under the freaking casing for the cylinders? Like... Do I have to remove that top part in order to get to them, or did I miss something?
https://www.sau.com.au/forums/topic/264957-changing-sparkplugs-help/
you have to remove the coil pack cover. the black bit with the nissan 2500. there is 8 allen key bolts holding it on. removing the crossover pipe makes it alot easier to do. then you have to remove the coil packs and the plugs are under them.
<br />you have to remove the coil pack cover. the black bit with the nissan 2500. there is 8 allen key bolts holding it on. removing the crossover pipe makes it alot easier to do. then you have to remove the coil packs and the plugs are under them.<br />
<br /><br /><br />
Ouch... Is this something that a person with no mechanical experience should be getting into without the possibility of messing up their car or...?
Yes you need to remove the cover covering the spark plugs to get to the sparkplugs.
You could also test your psychic abilities on it, but in the end you will have to remove the cover.
Edited by madbung
don't bother removing the crossover pipe, you might need to loosen it a bit but it should slide out ok as is.
Back your self a bit, it's an easy beginers job and you'll be happy when you've achieved a finished job.
(saves $$ also)
Edited by madbung
<br />don't bother removing the crossover pipe, you might need to loosen it a bit but it should slide out ok as is.<br /><br />Back your self a bit, it's an easy beginers job and you'll be happy when you've achieved a finished job.<br /><br />(saves $$ also)<br />
<br /><br /><br />
Thanks a lot for that guys.
easy diy job.... just dont over tighten and snap it off in there....
before you start make sure you have an allen key set, a socket wrench set a, screwdriver set and a sprk plug remooverdoova :D
If you want some more info check out this link http://www.skylinesaustralia.com/forums/RB...ark-t42819.html when ever you want to tackle anything you are unsure of check the tutorials section, there is a good chance there will be something helpfull in there.
Two things i did to make it easier on future changes was to leave out the one all key bolt just under the cross over pipe that is a bitch to get to with the cross over pipe on, also at the back of the cover there is a bit that goes down 90 degrees, as you try to slide the cover out it always gets hooked on the coil packs and the wiring, i cut that off so now it just slides out with ease, dont even need to loosen off the cross over pipe.
Edited by W0rp3D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
