RB30 can be done with stock bits for 3k. - PM sent.
a garrett gt30/40 with .82 external gate exhausting housing, cubes uses the same turb on his rb25/30 i think but is interl gate
No Cubes :( uses the 6bladed .6 port shrouded GT3076 .82 IW.
The GT3040's are good but they are a tad lazy. The power delivery feels like it lags a bit then comes on with a rush. The 76 however is linear and much more tractable.
The larger 82mm compressor paired with the GT30 .82 rear doesn't offer any more power compared to the GT3076 unless your running better than 98ron pump fuel. The hot side becomes a restriction. :)
Or.. GT3040 with the 1.06 rear can push close to 340-350rwkw on pump fuel with cams etc. BUT with the additional lag you may as well drop on the GT35r .82 and push just that little bit more. Where does it end. :banana:
Back in the day when the GT3076 was a 7blade (not current 6blade) the GT3040 was definitely the way to go. Hell even the Gt3071 was a better option than the GT3076 7blade variant.
  • Replies 49
pm replied, thanks heaps!
seriously though, unless you have access to internal & external micrometers, plasti-gauge, torque wrenches, etc or understand the importance of sequences, preparation for initial fire up and absolute cleanliness.......don't even think about assembling your own motor.
I do have a variety of tools on my disposal and as mentioned before have helped with rebuilds so i know what is required, its gonna be harder doing it myeslf i know, but we all gotta start somewhere. As far as machining and balancing etc. is concerned, that is the only part where i will have to pay a professional as I wouldn't want to attempt it myself.
After all the reason for starting this thread is seeing who here has done it so in case i do get stuck i have a bit of reference and first hand experience to help me through it. And it helps others who are thinking of going down the same path and i know there are a few on here.
I hope not :P
Now its a waiting game till someone comes round and buys my bike so i can fund this.
Pricing up forged rods and pistons I've found cheapest prices to be around $1200 + piston rings. Not sure on brand of rods (from US) but acl pistons...
Acl race bearings rod and main just under $200
Sucks its a long weekend so cant ring up anyone else but that's what i got so far. Decent prices?
Edited by tx3_90
I hope not :laugh:
in the latest fats fours and roataries mag there is a rb25/30 build up feature part1
No need for forged pistons and rods if your only aiming for 250kw to 300kw
agree on the rods.......disagree on the pistons
detonation even at 200kw can kill stock ring lands.......then again, severe detonation can kill forgies as well
all this talk on here now makes me wanna rebuild my dud 25 with a 25/30 setup....the bottom end is gone so should be able to slap on a 30 bottom and as long as other things are fine should be a decent setup.....but i believe that there is more to that than it being as easy as 123
http://users.tpg.com.au/cobra30/twincam.htm
http://www.ripsltd.com/index2.html
RB30 Stock internal bottom ends start at NZD$4,000 rwd or $5,000 4wd (suit up to 600hp and 7200 rpm)
$4000nzd = 3,243.59 AUD and shipping fron NZ is about 400-450
EDIT
http://www.skylinesaustralia.com/forums/R3...ion-t15420.html
bottom of first post has a download
3rd post 1st link :(
Yeah it is possible to achieve 600hp with a stock bottom end but id rather do it safely and reliably, do it once and do it right. If there is a slight balance issue when pushing those figures, I'm certain a forged bottom end would be able to compensate much better.
As far as forged rods are concerned, I've contacted this guy over e-mail and he told me he sells em on ebay. Here is a link for those who are interested... http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=400023741957
Not a bad deal bit I've never heard of that brand, claims that they're good for 1000hp at 10,000rpm with upgraded rod bolts.
do it :P its not that easy, but have a good read through the links Steve put up.. pretty much everything you need to know is covered.
Edited by tx3_90
600hp is ~450kw, but i guess its better to be safe than sorry. If you get a reputable workshop to do the balancing, i dare say there wouldn't be any balance issues?
450kw at the engine... take around 18% power loss through drivetrain and you're at roughly 370kw at the wheels which is still fairly safe for my application in theory. As mentioned rb30's tend to have a balance issues so that's another thing where money is gonna be an issue.
I'll be going a ATI Harmonic balancer. Apparently good for 1000hp
Do you know how much these usually retail at? Ive had a look on their website but no pricing for import motors.
Have a look at this thread and Pm the organiser. http://www.skylinesaustralia.com/forums/Ac...html&hl=ati
He was saying on the last page he has a local supplier to get them from now, but never again at the prices in the thread. Also note u may need to remove your A/C.
I'm currently getting 044 fuel pumps off him with no drama's so far.
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
