Hey all just wondering how much u would pay for my car if u were buying it? and if i would be better off selling the stereo seperately?
Car as Follows:
R33 GTS 94 Model
91000 k's
Garage ***ui Front Bar and Side Skirts
Custon Rear Bar
17 inch Chromies
EL Guages
7.5 g's worth of comp stereo including TV and X-Box
Custom Boot install
Slightly Lowered
Genuine Skyline Floor Mats
El Guages
Apexi S-AFC ii
Speco Tacho and shift light
Autometer AF Ratio Guage Pillar Mounted
Coby Extractors
HKS Super Drager Cat back system
High Flow Cat
Momo Steering Wheel And shift Knob
Full underbody Neons
Strengthened Turbo Clutch
Bendix Ultimate Pads all Round
I think thats about it, cars has been serviced every 5000k's
Nehelp? im unsure as to ho much i should ask for it?
Cheers
John
https://www.sau.com.au/forums/topic/26503-how-much-would-u-pay-for-this/
id suggest selling the stereo components seperatley as you will not get decent value for them been sold with the car.
The system is personalised to you and sounds like a nice setup, but a potential buyer might not see it the same way. But you could be lucky and find someone after exactly what you have.
seperate the tv and xbox, CD player in the car always heaps to sell though.
mate u could try puttin it on the market at $17k truth is it wont go for that hey, mines on at $15,900 and the highest offer ive had is $14k, and it looks like thats wat ill be sellin it at that! i think youll be lucky to get $15-16 for it and like nismodified said, sell the stereo componetry seperate to get maximum price. it sux that all the money u spend on mod's u really dont get back :P
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
