Hey guys i recently bought a r33 gtst with a KKR560 internal gated turbo.
By reading some users comments on kkr they arnt the best? Ive just blown mine aswell.
What i would like to ask is the internal wastegate on this turbo is one ive never seen before. It looks to be welded up from factory and has no way or being incorperated into the dump pipe? The wastegate flap is unable to be plumbed into the exhaust by the looks of it? Also it looks to be welded up?
http://www.otomoto.com.au/kkr/KKR560.html
Thats the turbo as you can see the flap looks to have afew spot welds holding it shut?
Can anyone tell me how this turbo would control boost with it being welded shut or am i just missing something?
Any help would be greatly appreciated
what to you mean blown? exhaust wheel smashed out? seal went, whats symptoms?
more details..... I here "my turbo is blown" a fair bit, usually its something else, poor install and/or leaking IC pipe etc
thanks mitchy that what i thought but without having the turbo off the car i assumed it was welded shut.
well i was driving and dropped it back from 3rd to 2nd and i heard a loud clap noise and there was quite abit of blue smoke out the exhaust i think the turbo has dropped the seals.
my car is the actual one on the otomoto websit the dyno chart is my r33 http://www.otomoto.com.au/kkr/KKR560.html but not running 22psi anymore. Its at 18psi
i would say you may of indeed blown seals, i saw a 2JZ send the exhaust turbine wheel into the cat, followed by lots of blue smoke.
KKR are dodgy from what i have read, however what i have read would lead me to beleive that they are reasonably safe at lower boost levels.
how many Ks has it done?
its about a year old say about 20000kms on the turbo
i will check all ic pipes aswell
i have checked the turbo there is no oil in it or any shaft play. The car idles fine for 20seconds then up down up down.
I think it might be something else. Might be AFM? are the r33 ones common to play up?
When it happened i down shifted from 3rd to 2nd and i heard a loud "clap" sound followed by smoke out the exhaust and car when reving past 2.5k starts to splutter.
anyone know of what it could be?
sounds like pipe work to me. check you havent split any silicone and just double and triple check every clamping point from the compressor housing to the throttle body.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
