  • Replies 47
Posted Images
coool speed limiter removed
Nissan has changed the set up on adm, edm and 2010 us cars
euro very close to being finished and im sure ADM will follow shortly :P
Good stuff. Who is doing the work and are they only working on the UK cars?
  • 4 weeks later...
when's the ADM accessport coming out??
Just got mail today that Cobb should have the ADM version finalised next week...can't wait! Also got mail that the cat back exhaust adds next to no extra power (assuming the mid pipe and dump pipes are already in).
:D
The first ADM car was done during the week :)
Base stage 2 results were impressive but more work will be done to provide an even better tune for ADM cars in the next few weeks since these base results were not ideal AFR's (Very rich - so very safe).
But you can contact Ray at R.E.Customs or PM me if you want to get your hands on one.
See below the results for the local ADM car with a mid-pipe installed before and after the stage 2 base tune.
The first ADM car was done during the week :teehee:
:P
How come the car was recording only 260kw to start with?
I wouldn't be too hung up on what the number says as all dyno's read different and there are a zillion different other factors to consider. That same car might read 300 stock and 360 with the Cobb on another dyno.
But what needs to be looked at here is how much of an increase in power and torque there is over the base value given the same dyno and conditions. Very impressive given there's nothing else done other than a flash tune between the 2!
wow, I know all dyno's read differently etc. but still all JDM cars i've seen on various dynos read between 290 and 310, and all the ADM cars I've seen seem to be around the 270 mark. but with nothing fundamentally different between the models I would say you can get it back with tuning.
and I know of one car that tried the uni-chip and it actually worked quite well. this was a year ago though and there are definitely better solutions out there now. given how far things have moved since a year ago I would be looking at a cobb AP if you just want a very basic upgrade and leave it there, or the haltech platinum I reckon is the gun choice now.
My ADM R35 put out 295.5 on the dyno at 12 pounds. I'd be interested to know what the boost was on the car that had the Cobb installed.
Cobb has had quite a jump on Haltech, has been widely used in the US, and has a proven track record. Will be interesting to see the results with Haltech over the next few months.
just wondering what people are doing regarding factory warranty?
can we just reflush before services or would they be able to find out?
Guys just found the Sydney dealer for Cobb. Their called MPS Garage, any one heard of them? i think they started off just doing Mazdas but now do other makes.
they have supplied workshops in Sydney already and i've also been told they have some in AP's stock
http://www.mpsgarage.com.au/shop/product/1...accessport.html
    • I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
    • You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
    • Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it! With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying. Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course. I feel silly now haha. ok I think I know what to do next. Thanks man!
    • Yes correct, the guide coat is showing low spots, in this instance the low spots are pin holes. I agree wetting the areas makes it more visible (but you can see it's there before you wet it as well lol).  Once the panel is flat, the guide coat will be gone
    • I wouldn't do it outside, the contamination landing in the paint, the wind and a million other things will drive you crazy.     That's a way too big of an area to use your single stage putty on.  Pretend it's all filler and those pin holes appeared, you'd then use the putty on those pin holes.  They are still pin holes, hmm I expect a few coats of high fill primer could deal with those.
