Since i've got manifold/turbo/dump/front pipe off, i want to clean up the insides to remove casting marks/rough welds etc, and maybe a little bit of shaping on the manifold. I'm thinking an electric die grinder is the tool for the job. I dont want anything air powered - no space for a compressor.
Any suggestions on make/model or should i use something else?
https://www.sau.com.au/forums/topic/265055-exhaust-side-cleanup-what-tool/
damn I was going to say air grinder was the tool for the job.
I guess dremel at low speed and a lot of stones if you have to go electric
How about Makita GD0600 HERE?
Some say that a dremel is underpowered for this work, and this one is the right price for something that wont get used much at $137. BUT a dremel is more useful for other things...
Hey buddy you want a high speed tool the more rpm's the better! get yourself some "flapper" wheels 60-80 grit and a carbite de-burring tool to take the bulk off then use the flapper wheels to clean things up and smooth it out.
If your iround the sth eastern area I would be happy to come out and give you a hand I've worked on supercars for the past 4 years so I'm not too sabby at these things anyhows let me know.
And yeah an electric die grinder with variable speed would be the go, I do prefere air powered tools and have some if your in the area pm me anyhows good luck with it mate.
Sorry mate just saw you were in Sydney any help I could give you just let me know
Edited by The BOP
So 20,000+ rpm is important, but what about variable speed? It looks like i need to get a pro one to get variable speed and its going to be triple the price...
Also, are the carbides ok for stainless as well as cast iron?
tnx
steel bits will work on both,
there are alloy bits out there too with a bigger toothing to stop them clogging, dont get these for steel.
  • 4 weeks later...
Yep ! Ive seen that Makita die grinder and for the money it aint bad ! Ive had an AEG one, with a thinner longer snout, for about 20 years and just reciently had it serviced after a lot of years of hard porting.
But the money is in buying good quality tungsten carbide cutting tips !
Good ones run up to about $60 each.
Ive got a tear dropped shapped one that I got when I bought the die grinder and its still going strong.
As Craved said there are 2 types one for steel and one for alloy but you can get away with the steel ones for alloy if you have a bar of soap on the bench and you just hit the tip, while its going, into the soap every so often and will it stop the alloy from stickin to the tip
The $137 makita was fine. I used a single stone tip which didnt seem to wear at all, and a "flappy" one that seemed to wear quickly. I guess a carbide burr would have been quicker but i didnt have much material to remove.
  • 5 weeks later...
  • 3 weeks later...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
