are these compatible with or do you have a similar item that achieves the same result with the Xanavi set-up in R34s - providing another more direct option to feed in av in that set-up in lieu of using the connectors in the boot?
  • Replies 41
bose doesn't matter. this works off the OEM tuner as I stated above. price is market dependent $80 is the norm at this point in time.
KVR,
Custom solution for yours - no other way.
  • 8 months later...
Digging up an old topic but...
I'm looking at using the AV input because I don't want to remove the factory features.
Being limited to RCA Composite video is making it hard to find suitable equipment.
There are a couple options using S-Video and adaptor leads.
I'm trying to avoid using something like a VGA converter box.
Are there any options for patching a VGA (or similar) signal straight into the factory LCD screen?
in short - no. you can patch a box into it but the result will be the same. NOW if you can get colors and CSYNC out of what ever you are doing then yes it will work. it will be a custom solution to do so.
Would this allow me to view a Navigation App on the OEM screen aswell as allow me to view videos and album information. ie:- replicate whats showing on the iPhone screen onto the OEM Screen ? Is there much lag if any ?
Is this a plug & play type of job that I maybe to pull off or should I obtain services from you or Rob B ?
Sorry one more, Do you provide the dock or must I source 1 ? If so are there remotes available or must we control the iPhone/OEM Screen through the iPhone ?
Dammit another one, Is it possible to view a Nav App and listen to music at the same time, either through the iPhone or through the Head Unit ?
If you might remember my cd stacker died and I was 1st thinking about the Pioneer Avic 900 ( Great Unit ) , but at the end of the day I will only be using the Nav and all of my music will be coming off the iPhone , so this seems like a great idea and I won't have to wait aslong to get it, What do you think ?
  • 1 year later...
Awsome If you wanna send your bank acc details to me and the amount ill put it throught. [email protected]
send me an email to [email protected] with your full name,shipping details and we will go from there. I'm with westpac so it should be fairly easy to get the money across.
as a reference:
this is what I sell.
plugs straigt into the OEM box. no dicking around.
I have purchased "cable 2", what does "cable 1" do?
And on the side, do you know if the video signal from the TV unit to the video screen is composite, component or propriety?
Does this work with the TV Tuner that is installed in the 370GT, 2007 Model?..
Again if it does assuming this would mean that the picture would display on the screen when it is in TV mode. Leaving the AUX still free. And you just pull the output cable from the TV unit and replace it with this lead?
Also by Colors plus CSYNC you mean, Similar to SCART output, yes???
If so what sort of quality would this give you, what resolution is the screen, as my model is a digital receiver is there a different lead that can be done to get HD component input??...
Thanks Chris..
