hi,
i just got a gts25t r33.. i seem o have a problem with the wheels (i guess). it's steering left even on a flat road.... i took it to a local mechanic and did wheel alignment.... but still same... i was told by a tyre shop guy that the car needs a camber/caster kit..
never heard that before.. any idea why this is happenin.. help appreciated. thanks
https://www.sau.com.au/forums/topic/265064-wheels-pulling-left/
Hey Arun we really need to results of the wheel alignment to understand. When something is bent often the shop will adjust it as best they can and just leave it, or as you said tell you what you need to do to straighten it.
Personally I'd rather replace the bent arm than put in bushes to mask the problem but bushes can be a cheap option depending on what the problem is.
Also....because aus (and jp) roads slope to the outside (left), the standard alignment settings have a little more camber on the left to minimise it pulling that way. So it could just be the standard setting or even the slope of the road you are checking it on.
Swap the front left wheel with the front right wheel ...
NO. NO. NO. NO.
Swap the fronts with the rears. NEVER swap radial tyres side to side. That causes the tyre to rotate in the opposite direction, and that totally roots the setup of the underlying tread belts. Then you get a symptom of "out of alignment".
hey duncan,
thanks for the reply man... what a coincidence.. i changed the bushes already.. but no use... and about the slope roads, i have lancer, that drives straight ( i even tested takin my hands off the wheels). so i came to the conclusion that the left front wheel is bent inside.. nyways i am goin to RACEPACE next week for service... hope BEN can help me with that...
cheers
Edited by zippo
NO. NO. NO. NO.
hey bud,
thanks for savin me man.... :laugh:
yeah Ben seems to know his stuff, plenty of impressive cars out of that shop. It won't be the wheel itself that is bent (than feel like a wheel out of balance) and probably not the hub/upright either. Normally it is the lower control arm and/or tie rod that are bent but I'm sure he can work it out.
On bushes, there are 2 types you can get, regular or adjustable. Unless you put in adjustable ones (and you shouldn't have to in a road car unless you've done something to stuff the alignment like lower it) they won't help straighten out any problems.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
