  • 3 weeks later...
I like the Red Lip around the wheel / rim.
Have fun cleaning White wheels tho... Haha!!
Nice and neat, can't complain.
What earth wiring system your running from your battery?
i think the red lip around the wheel/rim will suit better once iv painted my calipers red (nissan writing in white of course)..
Not sure about the earth wiring kit... all it says on the lil black/blue box is "Hot Inzm Kai" and "made in japan".
Is the earth wiring kit meant to connect to the positive battery terminal as well??... i found that a lil strange.
Right... So its a... Hot Inzm Kai LOL!
I believe (after translating on the internet...) It's a Battery Stabiliser...
Quote from - http://www.honda-acura.net/forums/92-civic...stabilizer.html
http://translate.google.com.au/translate?h...l%3Den%26sa%3DG
"A capacitor should discharge more quickly than a battery. What happens is some of the charge is stored in a capacitor so the battery has to work less. I google translated the japanese webpage and they mention quicker starting time. But judging from the size of this box, the capacitor is probably not that big. When you think about how much current is discharged by a battery, the capacitor will probably have no effect. They are attempting to minimize the inrush current coming out of the battery from what I can see. Do they have a size on the capacitor?
They also bring all the grounds to one point on the negative battery terminal. This is considered good grounding practice to minimize ground loops. The way autos are grounded now, the grounds could have different voltage levels."
Iam guessing that's your Blue coloured cables...
What's the thicker Red Cable?
Does it hook up to the back of your engine? Or is it bolted against the fire wall or to something?
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
