The time to sell my 1998 R34 GTT has come.
Reason for sale is that I want to get back into forest rallying and I cannot afford to keep the Skyline. I would if I could!
The car has always been garaged and religiously serviced (I am a mechanic) every 3000km, using Castrol products. Always warmed up/cooled down. The car has never missed a beat and has been a pleasure to own, modify and enjoy! It has never been in an accident - any inspection welcome!
It has travelled 64500km.
Engine mods:
GCG steel wheel ball bearing highflow turbo
Power FC
Greedy boost controller set at 14psi
Walbro in tank pump
Sard fuel reg
Nismo 480cc injectors
Splitfire coilpacks
Drift pod filter, cold air pipe and underbonnet heat shield
Monsta front mount
Full turbo back exhaust, high flow cat and HKS rear section from cat to tip
Poly (hard) turbo intake pipe instead of standard soft rubber pipe
Tuned by Micks Motorsport to 230rwkw
Just Jap alloy radiator and twin thermo fans
Genuine Nismo low temp thermostat
Oil catch can
Brakes/suspension mods:
Nismo S tune suspension with 4 way adjustable shocks
Just Jap radius rods
Just Jap upper rear camber arms
Just Jap HICAS lock bar
QFM A1RM pads all round
Master cylinder stopper bracket
Lucas racing brake fluid
Street legal braided brake lines
Interior is standard and in excellent condition. I have never smoked or allowed anyone to smoke in the car. Has a full set of factory mats.
Only interior mods are a Saber boost gauge and Nismo gearknob.
YLD34T number plates included and registered until September 2009
PRICE: $23900 o.n.o
Please call Toby on 0409 903 669 for more information.
Edited by yld34t
https://www.sau.com.au/forums/topic/265083-r34-gtt-white-coupe-64500km-230rwkw/
  • Replies 45
sorry mate, cant even reply to pm bcos of the min post thing.......
is that for full comprehensive or just fire n theft?
also, howre the maintenance costs? i ask bcos its not exactly stock...
and do u know how many owners since landing in oz?
sorry abt the q's, but i gotta sell it to the missus
No probs mate, you have PM!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
