R32
GTST RB20DET 2ltr,6 cyl,dohc,turbo 160kw@6400rpm 2634Nm@3200rpm 1998 RWD M/A
GTS4 RB20DET 2ltr,6 cyl,dohc,turbo 160kw@6400rpm 263Nm@3200rpm 1998 4WD M/A
R34
GTS RB20DE 2ltr, 6 cyl, dohc 116kw@6400rpm 184Nm@5200rpm 1998 RWD M/A
GTS RB25DE 2.5ltr, 6 cyl, dohc 142kw@6400rpm 231Nm@4800rpm 2498 RWD M/A
GTT RB25DET 2ltr,6 cyl,dohc,turbo 206kw@6400rpm 363Nm@3200rpm 1998 RWD M/A
thats the best i could find :banana:
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529009
R32
R34
cheers ,mate
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529021
R32
R34
Nice buddy!
R32 Wins hands down.
+ if you got the GTS4 you could give it a bit of a launch and gain the head start.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529041
Nice buddy!
it really depends....
the Turbo would be alot more fun to drive...
the non-turbo will get boring after a while.
but then again, R34 is alot more modern and newer.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529065
Yeah more modern and newer for sure, as the engine in the R34 would be revised and refined.
Performance wise... In this case the R32 FTW!
BTW we are talking GTS-T / GTS4 vs GT... Not GTR.
LOL!
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529072
LOL!
engine in the r32 is out of a fairlady,(red top rb20det) rwd mine is rb25de neo (rwd),would a better ratio in my diff increase my chance of winning? both our cars have same sort of mods,what can i do to guarentee a win without turbo? my car is tiptronic so i dont have to worry about shift times,
was going to get a shift kit cold air intake and cams,im also picking up a 4" mandrel bent exhuast :banana: to big i know but its right price right time sorta thing.
what else can i do that will be relativly cheap and not to noticable (visualy)
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529108
LOL!
yes i know were talking about GT R34 Vs GTS-T R32.
my point is, you must admit...thats a big hike in age difference there.
performance wise, yes the Turbo would have alot more potential and pleasure to drive.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529227
was going to get a shift kit cold air intake and cams,im also picking up a 4" mandrel bent exhuast :P to big i know but its right price right time sorta thing.
Fairlady? ... I have only hear of an old school (Datsun) Z car as Fairlady's... Can you explain more?
Diff ratio... Might give you a bit better pick up of the starting line... An upgrade to a light weighted Flywheel will help with acceleration as well.
Tuning up your cams and the high flow air intake will help a lot as that's the heart of where your power is coming from.
ECU upgrade will help with your Air/Fuel mixture.
4" exhaust?!
2.25" will do you fine, BUT you can have what ever size exhaust as long as you tune your car properly with that exhaust on it.
i could run faster than that thing
LMFAO!
Yes true, this is a age difference for sure.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529329
4" exhaust?!
LMFAO!
ok thanks mate ill get on it,iv got full uras kit ill lower the car more for the race and remove any extra weight i can...how much $$$ should i expect to spend to outrun a turbo?,i know i have him at top end speed but i need the take of aswell,my car as it is beats supras on high and low end,and turbo subaru's can not pull away from me so im happy with that.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529480
Reeks of sweaty palms in here,
You're probably going to go backwards with a 4" exhaust, you're car needs the correct back pressure to operate at it's best. I doubt a 4' system will provide that on a 2.5 n/a, you could choke it down with some mufflers, but that defeats the point. A tuned set of headers and matching system would be my choice.
I doubt you'll get near a turbo's performance with any form of bolt on mods (nos excluded) Headwork, bigger valves, port and polish, cams, bigger injectors, engine management, bore, stroke or a 3ltr bottom end and a balance would be a good stating point if your genuine. Expensive exercise, then your turbo mate only has to bolt on a bigger snail and it's bye-bye again.
Seriously, love your car for what it is...the rest is a waste of $$$$$ for a small ego stroke.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4529533
Is that meant to be DETT ? I thought the GTR was the only one with 206 Kw?
no, the NEO RB25DET for R34 was also 206kw but lower Torque power than GT-R & if you put them both in either Straight line or track...the GTR would smash it
Think about it. The RB26 was 208KW 10 years before that engine, the rb25 was 180ish. In 10 years the rb25 goes up by 20KW, so i'd imagine that the r34 RB25 puts out more than the 208KW that they advertise.
well thats probably highly unlikely
because 206kw is what they call "Gentlemen's agreement", restricting it to 206kw... same as the EVO and STIs at the same time. (and mind you they are only 4 cylinders creating that much power)
The supra TT was tested on the Dyno in stock form... from memory it was advertised as 206kw but on paper showed up at around 238KW - 240kw. so i dont think the R34 GT-T would put out more power than the supra.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4530013
EVO's and STI's run rather high boost though.
Oh, that's true. but what i'm saying is, if they got a 10-15% performance increase on the RB25, they'd probably have something similar with the RB26 (they had bigger turbo's in r34 gtr's didn't they?)
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4530088
well the torque is different.... and Torque makes a big difference in a cars speed & acceleration.
Not really... The RB25DET actually uses the LARGEST Japanese OEM turbos you could buy.
It is a T3 style turbocharger...If you measure it, it is actually somewhat...bigger/larger than that of T28 Turbochargers in the RB26DETT.
yes the GT-T can be tuned to exceed stock GT-Rs power. the biggest advantage of the GT-T over the GT-R is being 150kg lighter.
But in the overal perfomance package on track, the GT-R is hard to match.
https://www.sau.com.au/forums/topic/265088-quick-question/#findComment-4530329
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
