Hi guys
Im looking to buy a NA as i just wrote off my last car (old car, small collission seems to have made a lot of damage, and therefore is a writeoff in the eyes of the insurance company)
On my green P's, so dont have a choice sadly
Looking for a R32 or R33, preferably stock and manual
Can anyone help me?
pm me here if you can :banana:
cheers
https://www.sau.com.au/forums/topic/265099-looking-for-a-na-to-buy/
LOL
ive seen this been told, and even one of my mates told me to do that and i almost hit him for being such an idiot.
+ parts a genuinely cheaper to buy for turbos than they are for n/a's if you can friggin find the parts . but then again i guess many of the n/a owners on the forum get joe the mechanic down the road to do the work for them.
learn to maintain your Japanese handy down . twat
Handy down? lol stooge most people here earn their own cars. Dont be giving out advice on something you clearly know nothing about because it just takes up forum room.
im not even going to dignify that remark , with a response
anywho back to the topic. in regards to this thread . many of my friends have been able to squeeze through there exemptions by passing 'their car' off as a business car and applying for it through the rta . do some investigations into it. i assure you it will be worth it
butch, u clearly dont know much about turbo vs n/a vehicles.... you say put the n/a stuff on.... is that including raising the compression? does that include changing the ecu? because otherwise the car will run like ass and a corolla will crap all over it.... u'd struggle to get up hills....
in the end...after u change headgaskets/exhaust manifold/intake lines and pipes/block of oil intake and return lines/block of water intake and return lines/exhaust dump-front/ecu/and the other crap.... u'd wish that the bloke that told u to do it on the forums had keept his mouth shut about a topic he knew little about......
gl with the search thabsenceofcolour, the only thing I can say to u is wait for the right one to come along, it may take a while but it is worth it.
Adam
Adam
cheers bro
seems like your from my part of town :thumbsup:
another question about buying an N/A
would i be better to:
1. spend a fair bit less on a car that has done more k's and try and source a newer motor and put it in (thinking an RB25) or
2. spend a bit more on that elusive car that has done less k's (havent seen many under 100k, but looks like importing one i can get something around the 60k mark for about 10k or so)
tips that will help would be appreciated :P
Just remember that most of the cars that come from japan have had the clocks wound back or the dash changed so you never really know how many k's they have on them.
Mine had just under 200,000k's when i got it, 20,000 later and a lot of abuse from a hi flow wound up to 17psi its starting to show signs or wear, if i was you if everything looks good (rust, interior, hanging panels and general over all condition) get a thorough check done on it and go from there, these engines with a turbo on them has been proven to handle the k's if well looked after, no reason why you cant find a good high k one for cheaper.
What the guy above me said is spot on.
Assume that EVERY R33 has been wound back. I'm not saying they all are, but you really can't tell on some.
With that in mind, you pretty much can ignore the number of k's and just look at the condition of the car, how it drives, etc.
Be extra wary of any car under 100,000km because they're almost certainly wound back, and you'll just end up paying more for nothing.
yeh it sucks that it can be pretty easy to wind back the kms....
in my opinion, i still wouldnt go for skylines that have done over about ~150,000.... some may be fine and well looked after, but others I would say could start to show their issues at that stage....
I paid 12,000 ready on the road + insurance for my non turbo 33 gts4 in 2006... with apparently genuine kms of 84,000.... the racv inspection (I think its ~$100-200, depending on how indepth they check, tells a massive story... I did it 4 times... and 4 times it saved me from buying absolute lemons, even though they looked really good.... on the 5th time they said shes a really neat example and the kms seem about right and it was mine.... overall, i looked for about 9-10 months before I found 1 that was decent...I know now the hunt for non turbos is much higher due to the p plate laws.... still though, im happy I waited that long because the engine is strong and I have turboed it she still goes 100% perfect...
I had just given everyone a verbal warning telling everyone to take it easy!
butch and W0rp3D you both now have a warning!
when you both signed up the rules clearly state:
http://www.skylinesaustralia.com/forums/boardrules.html
Section 2
Treat all members with respect and courtesy - We will ban any member(s) who make personal attacks, threats or mistreats any other member in anyway (discretion is up to the moderator at the time of the offence)
W0rp3D you are correct in the facts, however the execution needs work. I expect a little more maturity from a long term forum user.
Butch you can't go around the forum swearing and giving misleading information. Smarten up if you'd like to contribute further to the forum.
Rude and abusive remarks removed and thread reopened. Next person to step out of line receives another warning!
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
