310 wide
710 high
18" wheel
so they are damn big. off a porsche cup car or something?
18" wheel is 450mm so tyre is (710-450)/2 per side =130mm. 130/310 gives .40 aspect ratio. So 310/40/18 is about right.
Standard on a gtr was 225/50/17 which is 660mm high.
Depends, if it in inches it 31 inches tall and 71 inch circumfrence. Most companies with will give you height and rolling diameter as the affects diff gearing.
dayum...ok well whats the widest i could go on r34 gtt?
worry about buying a decent tyre first, better off with a better thinner tyre, than a worse wider tyre. understanding im judging a book by its cover, but going by ur avatar ur car doesnt look like it needs anything over 300mm wide.
300mm wide is what in regular size?
    • Damn, as someone who just glued the damn things in (very slightly askew but better) I wish I saw this, or someone made this. Would be worth linking this to Boosted International. They're always looking for product ideas and this is something they would likely make.
    • You know what, I'll double or nothing. Save your money, buy a V8 Manual Mustang in 2 years and have a more fun street car with better support and all that. I often tell people "if I could do it all again, I wouldn't". Sell your R34 GTT to someone, spend the 20k in difference between that and a 2018 Gen2 V8 Manual Mustang. I'll bet you will have the $ in your pocket by the time you spend the ~20K differential on mods and get them installed. Just planting this seed for future regrets. Blah blah, wisdom of people who would do it differently who are at the end of the road you are just starting on, etc. Car modding is often death by a thousand cuts as you wait to afford the next big mod. Imagine a 2 door Skyline with a 330KW N/A V8 Revving to 7500rpm like the RB25, with 315's all round.
    • Yes I'm going through a similar thing with my R33 with rust in seams due to dried out seam sealer cracking. After much research I settled on Penetrol. Read what it does and its done a bloody fantastic job for me. Pressure pack comes with a thin tube to get into hard to reach places.
