Free Bump! These rims are HOT. Premium colour sets them apart from other RE30s. Absolute bargain as these rims would cost close to $5K new with long waiting time. If I had not just ordered my new Rays rims, I would have snapped these up. Then again, I may still consider them as I am a self confessed wheel whore! :(
