  • Replies 269
Posted Images
lol true. will do the next one if i can. by then atleast my brakes will be better then stock.
but ye ill be there will bring mate along for some good pics and also video camera
sweet so if they ask its being run by SAU ye???
and ye ill enter when i have a car worthy to enter lol
Oh come on dude, no excuses. I'll be entering in a stock auto GT-T - we can be GT-T buddies. If you don't drive I'll be dissapointed.
Edit: just had a read. So I'll need a fire extinguisher, secondary bonnet catch and battery triangle - am I missing anything? :P
Anyone? :P
ok so I'm avalible to do this one.
(fly out at 6 am the next morning)
so sandown kinda scares me, not much run off areas.
if I do the DT will I get timings and be in the club championship?
Or so I just need to enter as the slow group and work up the confidence?
either way I'm there
cheers
martin
Anyone? :thumbsup:
yup, you need to have a fire extinguisher mounted properly in the car (not just screwed into the carpet). i made a bracket with mounts to the seat rails in mine. Blue triangle (just blue electrical tape will do fine) to indicate the battery location in the car, and finally the secondary bonnet restraint. if your bonnet on the car is standard it SHOULD be fine as technically it allready has a secondary latch, because you pop the bonnet with the lever, then you release the catch at the front... (mine is standard and ive never had a problem...) also dont forget, cover all limbs, so long sleaves and proper shoes are important. my mate once forgot about this rule and turned up in a short sleave shirt, he had to go home and get changed...
i think that covers everything you need, oh, most important, HAVE FUN!!!!! :down:
cheers
martin
i dont belive there is timing for the DT group.
you could always do the DT this time, get to know the place, then go for timing next time. :down:
its up to you.
Cheers. I've been meaning to get an extinguisher for the '34 for ages, this at least forces me to do so. Can anyone confirm the stock bonnet will pass? Or do I need to go out and buy a leather restraint or similar for it?
Also - the battery triangle - would I be able to use blue Painters Tape instead of duct or electrical tape? It won't hurt my paint and I have that at home.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
