  • Replies 269
Posted Images
lol true. will do the next one if i can. by then atleast my brakes will be better then stock.
but ye ill be there will bring mate along for some good pics and also video camera
sweet so if they ask its being run by SAU ye???
and ye ill enter when i have a car worthy to enter lol
Oh come on dude, no excuses. I'll be entering in a stock auto GT-T - we can be GT-T buddies. If you don't drive I'll be dissapointed.
Edit: just had a read. So I'll need a fire extinguisher, secondary bonnet catch and battery triangle - am I missing anything? :P
Anyone? :P
ok so I'm avalible to do this one.
(fly out at 6 am the next morning)
so sandown kinda scares me, not much run off areas.
if I do the DT will I get timings and be in the club championship?
Or so I just need to enter as the slow group and work up the confidence?
either way I'm there
cheers
martin
Anyone? :thumbsup:
yup, you need to have a fire extinguisher mounted properly in the car (not just screwed into the carpet). i made a bracket with mounts to the seat rails in mine. Blue triangle (just blue electrical tape will do fine) to indicate the battery location in the car, and finally the secondary bonnet restraint. if your bonnet on the car is standard it SHOULD be fine as technically it allready has a secondary latch, because you pop the bonnet with the lever, then you release the catch at the front... (mine is standard and ive never had a problem...) also dont forget, cover all limbs, so long sleaves and proper shoes are important. my mate once forgot about this rule and turned up in a short sleave shirt, he had to go home and get changed...
i think that covers everything you need, oh, most important, HAVE FUN!!!!! :down:
cheers
martin
i dont belive there is timing for the DT group.
you could always do the DT this time, get to know the place, then go for timing next time. :down:
its up to you.
Cheers. I've been meaning to get an extinguisher for the '34 for ages, this at least forces me to do so. Can anyone confirm the stock bonnet will pass? Or do I need to go out and buy a leather restraint or similar for it?
Also - the battery triangle - would I be able to use blue Painters Tape instead of duct or electrical tape? It won't hurt my paint and I have that at home.
Guest
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
