Crap brand and/or bald front tyres causing your car to understeer in the wet.
With the wheel spin your diff is probably loosening up from old age.
thanks for that
well my front tyres are new with around 90% tread on it
they must be shit than lol
well i own a 1993 r33 with 180 000kms
but in the dry it spins both wheels
thats what i dont understand??
https://www.sau.com.au/forums/topic/265233-ecr33-diff/#findComment-4531008
you have a viscouse lsd (sorry for the miss spell) means it wont allways catch lsd. so in the wet its too easy for it to brake traction and doesnt need to spin both. though like hamish said it is probably a bit worn (wear will make it looser and wont catch as oftern)
to fix this you could shim the diff which will make the diff tighter, just dont shim it too far or the diff will be locked. you can buy the shims from nissan for about 5 dollers each, you probably will only need one .8mm one. by memery it will take about 2mm to lock it. its not difficalt to do just a bit of work there should be something in the DIY section telling you how to do it.
panda
https://www.sau.com.au/forums/topic/265233-ecr33-diff/#findComment-4531669
What brand tyres do you have on the front? Also is the wheel allignment to spec? Because that can also affect understeer/grip. Another factor could be that you have wider tyres on the rear and skinnier tyres on the front causing the rear to force the front to understeer by the rear having more grip.
On the diff, I agree that you should shim it to tighten it up. The viscous lsd's do tend to single spin once they have loosened up over time.
https://www.sau.com.au/forums/topic/265233-ecr33-diff/#findComment-4531802
i dont think its undrsteer because the front wheels dont grip at all and slide when its wet when i turn hard
it the dry it grips and handles really good
either you've got ordinary tyres or the road surface is very slick and there just isn't much grip when it's wet. I have RE001's and sometimes find the wet grip to be pretty borderline, I was expecting more from Bridgestone's "premium" tyre. However road surface makes a huge difference, old polished bitumen has low grip while rough bitumen still grips well in the wet.
Rear diff choice does affect off-throttle handling, my R31 had a locked diff and would understeer badly into corners if I went in a bit hot. Any car with a 2-way would be similar but not nearly as bad. Standard viscous LSD will have no effect off throttle, they aren't exactly a tight diff.
https://www.sau.com.au/forums/topic/265233-ecr33-diff/#findComment-4541143
  • 4 weeks later...
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
