i suppose it would depend what size tyres they are
if you have the normal 16" then somewhere between 32-34psi would be fine.
32psi is actually a mechanics tale..
its a "one size fits all" kinda beleif...
alof tires require more and some less...
always look at the side of the door..... where the latch is...
for stock tires and rims, that should be the exact size of tyre and pressure.
You know its actually spelt "tyre"?
lol
no its not
Tire is American english
Tyre is Uk & Australia
Just like Grey is spelt Gray... Aluminium is spelt Aluminum...Kerb is spelt Curb... Mould is spelt Mold & aeroplane is airplane. :P
32psi is not a mechanics tale... most mechanics will tell you to set your pressures to more like 36ish, depending on the car/tyre.
Don't necessarily follow the tyre placard as they are usually settings that achieve best comfort rather than best performance. (Although this isn't always the case)
I run my pressures (stock 17" rims) at 40psi. The best thing to do is monitor the way the tyre is wearing. If the outside edges are wearing more rapidly than the centre, your pressures are too low, and vice versa. Keep in mind there are other factors that can influence tyre wear though, such as wheel alignment, driver, etc...
well personally i prefer higher...
higher pressures give slightly better fuel economy than one being lacking pressure.
Beleive me, ive worked at 3 car dealership service workshops during my apprentice ship years ago.. and that was like the universal one size fits all tale.
like i said, it depeneds on the tyre and the load
the tyres on my Toyota Hilux i pump it to 55Psi cause anything lower than that, it looks flat...
Geez, that would be rough as guts. You obviously never go off road with it then.
i guess its up to the owner at the end of the day then really. when ever i have had new tyres put on the cars ive owned they generally get pumped up to 32-34ish. but from what ive read from other people today afew are running at 40+. just have a look on the side wall of the tyre and see if it has recommended psi and go with it.
Well I wasn't just rambling either...I worked at 2 dealerships during my apprenticeship and then for a general workshop after that. And never did anyone I work with tell a customer to put 32psi into a sports car tyre.
Anyway, I'm also sure your hilux is probably running light commercials, not road car tyres. I also put 50+ psi into those kind of tyres, but wouldn't recommend it to OH RB for his skyline...
And I wouldn't class my tyres as 'lacking pressure'. They are wearing fine and the car uses about 11L/100km.
So in the end, don't put 55psi into ur skyline tyres lol. If it were mine they would be up around 40, and monitor it from there.
lol
no its not
Just like Grey is spelt Gray... Aluminium is spelt Aluminum...Kerb is spelt Curb... Mould is spelt Mold & aeroplane is airplane. :D
LOL
The tyre pressure is more controlled by the tyre itself. Check the manufacture's tech data for the recommended pressure.
Most manufacturers (car and tyre) recommend a pressure that will aid in the comfort of the ride, ie they are a bit soft. Add at least 2 psi all round, then add another 2 psi to the fronts.
and where did i state to pump 55psi into his skyline?!
i told him to check the pressure at the tag on the side of the door trim...
it should have the exact pressure and size of the tires....
my car runs on stock wheels.
I wonder if the front and rear got different figures? as I've seen the figures for other cars tire pressure and the fronts figures are always different from the rears.
You would see this mainly on track cars where individual tyre pressure's are essential for cornering, e.g. more psi in the back = more over steer, less on the front = more grip but more body roll and understeer..... its a fine line!
I usually run 35psi on my 18's and find that its a good balance between tyre wall stiffness and grip.
Hope this helps you....
I never said you did :(
I just didn't want him to be confused.
    • A bit of data is always good, beats the Facebook experts with their opinions I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
    • Correct And whatever you do, don't use an oil pump gear, especially the one that starts with the same letter as Santa and the last letter ends with the same first letter as Lagoon. Get a proper oil pump, like a Nitto, Tomei, etc. and make sure you invest in a big fk off sump. Won't go into too much detail, but I am sure it caused my previous built motor to go bang.
