there's an apexi unit in the car atm, so no troubles with the main harness and plugging that in as its a direct replacement..
just cant find the two wires i need to splice onto from the handbrake..
can someone tell me how to get to these two wires and what they look like ?
any help is appreciated, cheers
https://www.sau.com.au/forums/topic/265278-greddy-turbo-timer/
If you do not connect these wires to the handbrake then turbo timer will not turn the engine off if the handbrake is disengage thus if some1 breaks into your car while the car is running by the turbo timer they can still drive the car(although the steering lock would engage)
if the turbo timer is set up with the alarm this step can be skipped
some alarm will automatically turn off the turbo timer if someone puts their foot on the acclerator or any other pedals for that matter.
But either way the steer lock will engage like it was mentioned above.
so i hooked it all up, aside from the park brake wire because i still cant find it, will try in daylight 2moro.
question for anyone using these, does yours beep every second it counts down? at the moment mine is, and inbetween displaying every second of the countdown, it shows [ S i D ] is this all just because its not recognising the brake as being applied and a warning?
Same.. i have a greddy turbo timer... no SiD here..
Sound can be turned off... show me a pic of your turbo timer and ill let you know if its the same as mine... As i have the manual for my turbo timer..
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
