I am keen to make up some door inserts for your doors in your R32's I have the Original templates here at home and I am keen to make up some door retrims
They will be made from Black Marine grade Vinyl to keep the whole black feel going in your R32
Mainly looking at making the front doors at the moment but if there is enuf interest I will do the rear interior trims aswell ...
Looking at $30 per pair of doors if anyone is keen let me know and I will make some up for you ...
They are affixed to your door using spray adhesive just like the originals
The door cards will look like this only Black
if there is interest I may look into getting , Nismo , GT or even GTR logos embroidered into them
Edited by hr32gts
https://www.sau.com.au/forums/topic/265288-eoi-r32-door-trim-inserts/
Yeah no worries dude can do ... I have cartloads of the Black marine grade Vinyl to use so it is all good ... if ya can give me ya old trims to use as templates then were in business :P if I make templates of the 4 door then I can make more for other people so that's a bonus :thumbsup:
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
