i spoke to Al the otehr day about this, after i start my car and the engine fires i hear this crunching noise for a couple seconds, he told me its the stater motor getting dirty or something, if this is what it is should i worry and get it fixed asap or jut get it lookedat next service ? and what's required, is it easy enough to do myself ? worth just cleaning or should i replace the whole hog ?
cheers
https://www.sau.com.au/forums/topic/26530-crunch-on-start/
Starter motors are expensive. The only issue I've had with a starter motor in the past was sometimes it would crunch/grind instead of kick over (this was on a Mini). Eventually started doing it more and more until I couldn't get it to kick over at all.
When I pulled it out, it was full of scungy grease. I cleaned it all out and it put it back in and it was then fine. Might want to just pull it out and give it a clean, see if that helps. I'm not sure if your symptoms are the same as mine though.
https://www.sau.com.au/forums/topic/26530-crunch-on-start/#findComment-561310
