  • Replies 40
LOL oh, much more than that.... but most importantly, it means you're an idiot.
ok thanks, now i know not to give a shit about ur opinion next time i see one of ur posts.
ur probably one of those guys who sits in his garages in the nude polishing his skyline, with a container of polish in one hand, "some for you, some for me", then starts a thread when a rock bounces up and puts a chip in ur paint.
lols my heat gun and mallet didnt do the job still sometimes rub when i go over big bumps.
so me n mate attacked it with heat gun and a pole.
A1 job of rolling guards :)
why pay someone when u can do it yourself.
my thoughts exactly, poles ftw.
and i mean that in the most heterosexual way.
whip out the angle grinder, it works a treat! no paint cracks, no buckles, and does a much better job.
See what happens next time when someone accidently leans or bumps on your wheel arch a little hard, especially the front guards. The factory lips are folded back at 90 degrees like that for a reason, to maintain the integrety, strength and the general shape of the wheelarch. Grind it off and you've weakened it.
Edited by smok74
exactly, as a minimum u want to keep the lip, just folded up against the guard.
pole takes like 5 mins a corner not even.
driving to a place to get it professionally done and paying someone 40-50 a corner and seeing them do it in a few mins.
rather do it myself. and save time and money.
but if u guys like to get your tires professionally shined etc
go for it =]
yeh, there's no right or wrong way to go about it, if u dont plan on scrubbing rails or walls and u want ur car to look clean, professional is the way, but if ur not really fussed about minor details and u just want some more clearance, pole/hammer/clamps are fine.
GOD SOME PEOPLE DONT DESERVE TO OWN SKYLINES !!! YOU CRUEL BASTARDS !!! GRINDERS ? HEAT GUNS ? F*CK ME !!! FOR F*CKS SAKE, HAVENT YOU PEOPLE EVER HEARD OF 'DO IT PROPERLY OR DONT DO IT AT ALL ??????'
Dude, Ive had some workshops quote up to $200+ for each corner...... Your best bet is, get yourself a 'guard roller', Its a device, you remove your wheel, bolt it to the hub, and it contains an arm and a roller, starting at the middle, you work your way back and forth and tightening it up as you go, slowly and surely pumping it out, professionals use the same tool. Ive seen it for sale at VG AUTOPAINT at Girraween (NSW) for about $150 !!! you could even start your own business and get your money back after one job LOL
http://www.toymods.net/forums/showthread.php?t=26928
Go to this site, its got all the pics of what Im talking about.
Hope this helps.
Thank you for that pearl of wisdom Captain Obvious. As for the heat gun idea, applying heat during the procedure is acceptable practice. It's great that you take pride in owning a 'Line but FFS dude, lighten up.
Just so that people know, hitting the wheel arches with a grinder is in fact defactable - cutting into the main body. I mean, if the cop was stupid an un-observant, then it's all good, but these cops are becoming smarter and more clued-on within the modifying circles - lots of cops, especially highway patrols, are rev-heads themselves and if they really want to defect a wheel arch that been angle-grinded, then you're f*cked... If I was a cop, Id do exactly THAT to be a pr*ck just because that kid drives a Skyline ..... and dont say it wont happen....grinding the lip off weakens the entire wheel arch etc etc...you can return a pod filter to 'factory' with the stock airbox, but what are you gonna do about the hacked up wheel arch ? find some new guards and replace them I suppose....pretty easy huh ? especially those rear ones.....
  • 3 years later...
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
