Hi,
I was just wondering if anyone could give me decent suggestions on what to do about my situation, basically Im 18 and just got my red ps. I know I'm not suppose to drive a turbocharged car but my dad has given me his R33 skyline gts-t as he cannot drive anymore.
I can't really sell the skyline as it will lose alot of value and at the monment I can't afford another car. I live in rural area where there is no other transport and I live with my elderly dad who occasionally needs to be driven to the hospital. Has anyone got any Ideas on what I should do? I can't really afford to lose my licence either for driving a car im not suppose to. Ive heard that there are exemptions for situations like this but im not sure
https://www.sau.com.au/forums/topic/265306-what-are-my-options/
Buy a crappy runaround and use that instead. (Note i didnt say sell the r33, if you're in a rural area you could just store it somewhere. R33 GTST's are all losing money right now and they'll never appreciate in value anyway so just keep it and have something to look forward to when you get off your P plates)
Hi,
i personally would do the right thing just to be on the safe side....
not worth going through the consequences. you could always buy it in a few years time when it is alot cheaper
Easy, under your circumstances id at least try and apply for an exemption. They can only say no, and if thats the case...
Buy one of these:
Store the 33 and get it once your off your P's.
Hi,
Get a corolla man... ull love it.
Buy a tow car (commawhore or simular) and trailer, drive your tow car around and put the 33 on a trailer and come to trackdays/driver training, you dont have to go stupid fast, just get it out and have some fun.
My 2 cents.
Buy a old diesel cab chassis LandCruiser and put a crate on the back of it. You know, something in between waist and shoulder hight and good for leaning on and holding onto :D
The R33 is going to depreciate weather you sell it now or later so it doesn't really matter. I would keep it if it was exactly the way I wanted it (for me this would mean as stock as possible and immaculate condition, you may see things differently). If it wasn't the way I wanted it I would sell up and buy either the aforementioned LandCruiser or a Subaru of some description.
Then again, it would be good to see some fellow Riceliners when I go on epic treks to the bush :P
Apply for an exemption. Read the following though:
An exemption may be granted to:
A country driver who requires the use of eight or more cylinder Four Wheel Drive (4WD V8) vehicles if there is no practical alternatives
A person who can prove they owned the prohibited vehicle prior to 11 July 2005 or before an interstate/overseas licence transfer (attach proof of acquisition).
Note, only a provisional who has never held a NSW licence before his/her licence transfer can apply for this exemption
A person who can demonstrate any other exceptional circumstance, (attach any information necessary to support your exemption request).
An exemption from the prohibited vehicle condition will not be granted simply on the basis that the only vehicle available in a household is a prohibited vehicle.
Obviously in your case, you might get in under the "eceptional circumstance". If your dad is sick or whatever and needs a lift to the hospital every so often, i would be getting a letter from a doctor to support this, especially outlining that YOU are the only one or main person who needs to drive him, and then attaching the proof that the R33 is the only car in the family that can be driven.
If you have another family member at the same address with a non-prohibited vehicle, you have very little to no chance.
Here is the application form:
http://www.rta.nsw.gov.au/licensing/downlo...mption_dl1.html
FYI, it costs $30 to apply for the exemption, and you don't get it back if you get denied.
Hope that helps. All the best with it.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
