Hey
Im a new member and just got a few questions. I've got a 2000 Magna VR-X manual that is my pride and joy but recently I've been thinking of getting something different and skyline R34's have taken my eye, however I have never been in one or driven one so was hoping you guys could tell me a bit about how they handle, 0-100, power figures, fuel econ, reliability, ruggedness (ie how will they take being driven hard).
Basically looking for something that handles as good as my VRX, is a bit quicker (VRX does lmid/low 7s) gets roughly same fuel econ (I get 550-600). Looking towards N/A as I'm 22 and don't wanna be killed off by insurance but at the same time if any of you guys around that age have GT-Ts what's your comp insurance like? Im with shannons right now and pay about $1000 for bought price of $9,800 with all mods listed.
Really appreciate your opinions and info on the cars.
Cheers
https://www.sau.com.au/forums/topic/265344-35l-v6-vs-r34-na/
Hey
Cheers
Honestly, do the reseach yourself. Go to justcar.com and get an online quote. Google the NA R34 Specs and get the figures.
Some of these answers will take literally 10seconds to find. Then if you can't find some answers come back and ask.
550-600km? stay away from skylines.. :)
Couldnt have said it better myself.
End thread!
the r34 tank wont be much smaller if at all...
i wish i got even close to 550km on my 72lt tank :)
lucky to get 300 *cries*
lol yes but you do have a GTR, its not that exactly a car that competes against the Prius for greenest car.
lol finding an overpriced one wont be hard.
How do they handle? Comparing the 2 isnt even fair to the magna. Ones derived from a racecar, ones a family shopping kart. Im sure you can figure the rest out on that topic
Fuel econ? Ok, its pretty easy, if you drive like a dickhead all day with the revs high up in the RPM range and the motor loaded up all the time you'll use more petrol than shifting around 3500rpm with slight pedal pressure applied to keep up with traffic.
Well yes that the same for anything from a XR8 to a Charade, but the difference being what they actually consume. For example with calm no 'dickhead' driving the vrx does a averaged 9.8lt/100km with 'dickhead' sprints every now and then it'll put up a average of 10.5lt/100km. Was trying to see if you guys could answer questions like that.
Google isn't much help unless you have a GTR and wikipedia only has power figures, no 0-100, no torque figures.
Edited by JarRah
Good to see another Skyline enthusiast but this topic has been covered to death with comparisons to many cars. I would try a search on the forums because there's a mountain of info relating to all the topics you're inquiring about on SAU. Also, the VRX and 34 and completely different cars so it would be like comparing apples to oranges. Cheers mate
Have a read in the NA section of this site for actual fuel econ figures used by members (not manufacturers claims). Personally if fuel economy is a purchasing decision in a car i would advise to not consider the skyline at all. Dont forget parts will cost more, generally labour costs more aswel, hardly any local support from manufacturer etc.
Also, if your magna changes fuel econ by 700ml per hundred (9.8 to 10.5), thats only about $1 at todays petrol prices. Remember thats 91octane. Lets say an R34 has the same increase for comparison sake (as you're trying to see how much more a skyline costs), well the difference would be about $1.20. Who actually gives a sh!t for $1.20 when they get to drive a skyline instead of a magna? (not being rude, just trying to help out).
On the flip side, are you getting that fuel consumption figure from the onboard computer? If so and its anything like my commodore (chances are that it is), that figure is actually false. The figure is based on when the battery was last out of the car or when the ECU/gauge was last reset. Its an average, so to make it go up by 700ml may mean the actual econ for that tank may be something like 18per/100 but the computer settles on 10.5 as it hasnt been reset in a year or two and is averaging the last 2 years of all driving. Know what i mean?
Sure you tried google? I just googled "r34+gtt+spec" and on the first page of results got this;
Model: R34 Nissan Skyline GTT
Model Year: 1998.5 to present...
Engine Name: RB25DET
Engine Cooling: Water cooled,
Engine Configuration: Inline 6 Cylinder,
Engine Camshafts: Double Overhead Cam 24 valve,
Engine Aspiration: Intercooled Turbo,
Engine Valve Technology: NEO Variable Valve Cam Timing Technology
Engine Bore × Stroke: 86mm × 71.7mm
Engine Displacement: 2498 cc
Engine Compression Ratio: 9:1
Engine Max Power 206kW (276 bhp) @ 6400rpm
Engine Max Torque 343Nm (253 ft-lb) @ 3200rpm
Fuel tank capacity: 65 litres
Fuel type: Unleaded premium (RON 98+)
Fuel consumption: 9.4 litres per 100 km
Transmission: Type 5 speed manual
Drive layout FR: Limited slip differential (as standard)
Steering system: HICAS 4-Wheel Steering
Steering type: Power Assisted Rack & Pinion
Front suspension: Independent suspension multiple link system
Rear suspension: Independent suspension multiple link system
Front brakes: Ventilated disk
Rear brakes: Ventilated disk
Front tyres: 225/45ZR17
Rear tyres: 225/45ZR17
Turning circle: 10.2 m
Dimensions: Exterior length 4580mm
Exterior width 1725mm
Exterior height 1340mm
Interior length 1780mm
Interior width 1400mm
Interior height 1105mm
Wheelbase 2665mm
Front track 1480mm
Rear track 1470mm
Ground clearance 140mm
Weight: 1410 kg
I highlighted the figures you're after to compare. Remember thats the turbo specs, so the fuel econ should be even better again
Using your figures and theirs for fuel econ only;
100k's in a magna costs you approx: $12
100k's in an r34 would cost you approx: $14
....depending on the slight variance in prices from area to area. The difference is due to needing higher octane petrol than the stuff your magna runs on
Moral of the story for people in the future: Do a search :)
Cheers heaps mate. Just needed figures like that cuase if I go head with this just want a week to week idea of what the car will cost me.
The on-board computers in magnas will only go for 20hours this beep at you till they're are reset so they usually get done once a week. They're fairly accurate on the freeway but around town they are useless throwing up huge figures
Based on this should only be a slight increase in all round costs so yea this could actually be feasible
Already given a link for full spec's with 0-100 and 0-400 times
Incase you were to lazy to read or click.
Nissan Skyline R34 GT-T Specs
Dimentions
Length 4580 mm
Width 1725 mm
Height 1340 mm
Wheelbase 2665 mm
Turning Circle 10.2 m
Chassis & Body
Curb Weight 1410 Kg
Body Type 4 door sedan or 2 door coupe
Layout Front engine / Rear wheel drive
Wheels 17 x 7.5
Tyres 225/45
Brakes Ventilated: 4 pot front, 2 pot rear, ABS optional
Steering Rack & Pinion speed sensitive (front) HICAS (rear)
Suspention F/R Independent multilink
Engine
Type RB25DET- Inline 6, Twincam, turbo intercoolered NEO
Displacement 2498
Compression Ratio 9.0.1
Power 206 KW @ 6400 RPM (140 to 150rwkw)
Torque 343NM @ 3200RPM
Bore x Stroke 86.0 x 71.7
Redline 7,000 RPM
Fuel Injection Nissan EGI (ECCS)
Fuel Tank Capacity 65 litres
Gearbox 5 Speed Manual
Performance
0-100 6.2
0-400m 14.3
+1 :)
hey mate ill just simply answer your questions
i have a r34 coupe na
fuel economy around 400ks to a full tank (driven till light on then fill up immediatley) although i only put in bp 98 im guessing 91 in the manga.
A i have driven a manual 3.5l 2001 model magna and two verada 97 and 99 and the magnas will absolutley kill a r34 in straight line.
although handling wise, the magna is like driving a crashed boat and the skyline is like driving a race car if you compare them. to put into other words, the magna family are probably the worst handling cars i have driven, and a stock r34 handles extremely well.
The rb25 is a very reliable motor i have only had good experiences with them.
power figures I believe are around the 100rwkw mark stock (the n/a section goes very much into detail about n/a power output)
All in all they are a great car, personally i cannot handle driving a magna as it feels like a chore where as a r34 is a drivers car.
insurance wise i pay approx 770 full comp, agreed value of 23k
hope this helps your hunt mate
Thanks mate.
I know what you mean about stock magna handling, my old 97 exec was like a boat and this was in part why it died so violently (rain + understeer = broken axles). but they can be modded to handle great, yea not a skyline great but still I take my vrx for quick runs through the south coast national park and it just has mountains of grip. It has to be pushed pretty hard to get understeer and never gets oevrsteer, lift off or otherwise.
Having driven a 2000 Magna, they are pretty much the opposite of a Skyline in terms of handling.
Oh and yeah fuel consumption is pretty shocking in Skylines. Mine uses around 18L/100 (modded and too rich a tune), regardless of thrashing or not, which was about the same as the 5 litre SS I had before it (and yeah those dash computers LIE unless you reset them every couple of months.)
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
