Question About Apexi Power Fc
quick 33
 Share
hey people i just got a quick question ? , iv got a r33 series 1 and iv had the chance to buy a apexi power fc that is coming out of a series 2 and i was wondering if it can be remaped to suit my series 1 and if so can it also be set back to defalt for a retune ?
can someone help me please ;-)
It will work with no problems at all. As long as its for the same make "R33" (and the same engine) e.g. RB25DET and the car is Manual.
Also, you can reset the tune easily from the menu. Will need a tuner to retune for your mods down the track if you require.
Chris
what he said. the instal is as simple as unplugging your ecu and plugging the power fc in. then would recommend taking it to a workshop and getting it tuned for your car
Disconnect the negative terminal on your battery before you f**k around with the ECU.
Im pretty sure s1 and s2 computers are different, got to do with ignitor and coilpacks being different. Check with an online parts supplier like nengun ect and see if theres different part number for the PFC ecus.
Actually Mark Apexi used to have two different model numbers for the Apexi PFC for the S1 & S2...
However on closer inspection they were infact the same unit...
They made two different model numbers on their list to reduce the number of enquires from people asking if there were specific ecu's for the S1 & S2...
Hence the cause of this common question or assumption that there are two units in the standard pfc for the R33 (rb25det models)...
They would have been better off just changing the product description to say "suits S1 & S2" which is what they did in the end...
Bit of usless knowledge for ya...!
Haha..was getting a little worried. Allot of noise about nothing!!! Happy i was still correct! :P
ok nice so i found out that it is coming out of an r33 rb25det 5 speed manual ( the same as mine ) but i also found out the that the car its comming out of is heavly moded ( he used to race it )
so will the tune thats in the pfc @ the moment get me to the tuner without breaking anything cause even though my cars moded its nothing like the car its comming out of ?????
thanks.
thanks.
Thanks for your question. Happy to help.
When the PFC comes out of the "heavily modified" car, I would suggest you don't install this, as it would be using the same tune. (which could be dangerous if he's got increased timing, cam adjustments, injector duty etc).
Your best idea would be to take the PFC with you to your tuner and get him to install it...Takes around 5 minutes max. Very easy.
He (or she), will be able to do this for you.
Also, for my info....where are you looking to tune? My money is on Matty Spry.
Cheers and good luck.
Chris
Chris
im actually in maryborough QLD ( so just down the road for you) and i was thinking of taking it to Brad Smith in hervey bay , he tuned my first r33 i had and it was moded to the hilt and he did a pretty good job of it unless you no of some one in my area that is better ?
thanks.
it depends on how different the set up on the other car is to yours? mainly injector sizing.. as your only planning on driving to the tuner and not racing it lol. however if it was my car or one i was working on i'd reset the power fc to the base map just to be safe. depending on if your running bigger injectors u'll need to trim that down then it should run fine.
the far safe option is to just drive the car to the shop and install the pfc there. it only takes about 30 seconds. remove kick pannel, unplug computer, plug pfc in. done. why drive it untuned when it's far simpler just to drive the car with the stock computer and do it at the workshop
might have larger than standard injectors, z32 afm?
but he has a computer that is running his current setup... so keep the current computer... ahh forget it.
 Share
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
