1993 R33 Series 1 - 4 Door..
Very Nicely modded, tried to keep it as much of a sleeper as possible..
Just had a full conversion from auto, new reconditioned 5 speed turbo gearbox & PBR stage 2 clutch.
Turbo was recently serviced & is in perfect condition, also replaced all exhaust studs with stainless steel (which is a common problem)
Car is in almost perfect condition, not a single chip scratch or dent.
Even has original factory floor mats from showroom.. ha ha.
can pick a few little things but you'd have to be really fussy !
Currently tuned to 18psi which pulled 380rwhp.
Highest boost ever run was 22psi which pulled close to 440rwhp :P
Mods : http://www.skylinesaustralia.com/forums/in...mods&id=392
(prob has alot more mods but can't remember them all.. ha ha)
car has done only 100,000km & has had major service done recently.
Price is $16,000 Or Swap for something smaller + $$
Call me on 0433 134 626 if your interested
Edited by mrwatson
https://www.sau.com.au/forums/topic/265426-fs-r33-gts-t-4-door-5-sp-400-rwhp/
how many km's on forged motor??
Not too sure, the work was already done when i bought the car, i have done around 8,000km on it in 5 months on low boost as a daily driver.
The previous owner imported the car, had only done around 30,000km & had the car for over 10 years.
The work was done by "X-speed" in WA around 2 years ago.
Edited by mrwatson
  • 9 months later...
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
