No, no...
Just hasn't 'met' chook before, I knew it was a person just not sure who or how!!
Just thought Mr 'Buck' Rogers was the only messaih around here, didn't know there was another naughty boy.
(Check Monty Python if you don't understand)
As for the reference to Nth Melbourne, didn't you see the 'chookgate' scandal late last week?
Well this is the car i was keen on. You might understand why i didnt just go for a premium model...
But then i found out that its not a real deal s-tune, but rather a base model with just the body kit and wheels. No other nismo goodies in sight. It went for WAY too much, somebody must have thought it was real :D
The equivilent cost to us would be $38,000 landed and complied. Keep in mind that it is a 2004 base model with no leather, no tv, no bose system, and it didnt have any other nismo goodies (standard speedo, standard exhaust, standard suspension, etc). It did have a sunroof tho.
But yes, it is one hell of a hot car. I love the nismo kit especially with the bigger air dams and blacker headlights.
I have about 20 more photos if anybody wanted me to email them.
Way too much considering it's not a real S-tune and an early 2003-2004 model. but if it's a real S-tune you'd be having a headache if the engineer know it's not 'standard', you may be up for expensive compliance process or re-exportation...
I know prices can't compete to back when A$ was over 90 JPY, but for $38k+ in my opinion at the end of the day you'll be a lot happier if you have a premium... just keep looking till the right one turn up.
I agree.
You will be surprised how cheap they are now though, even with the yen at only 72. A 6 speed white 03 model non premium went for less than 1.1m fob the other day, which is what, $22k landed and complied??
Anyway. I dont like my chances of another nismo kitted one popping up soon, so i may just end up with a random premium of some sort..
Thanks for the help :D
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
