No, no...
Just hasn't 'met' chook before, I knew it was a person just not sure who or how!!
Just thought Mr 'Buck' Rogers was the only messaih around here, didn't know there was another naughty boy.
(Check Monty Python if you don't understand)
As for the reference to Nth Melbourne, didn't you see the 'chookgate' scandal late last week?
Well this is the car i was keen on. You might understand why i didnt just go for a premium model...
But then i found out that its not a real deal s-tune, but rather a base model with just the body kit and wheels. No other nismo goodies in sight. It went for WAY too much, somebody must have thought it was real :D
The equivilent cost to us would be $38,000 landed and complied. Keep in mind that it is a 2004 base model with no leather, no tv, no bose system, and it didnt have any other nismo goodies (standard speedo, standard exhaust, standard suspension, etc). It did have a sunroof tho.
But yes, it is one hell of a hot car. I love the nismo kit especially with the bigger air dams and blacker headlights.
I have about 20 more photos if anybody wanted me to email them.
Way too much considering it's not a real S-tune and an early 2003-2004 model. but if it's a real S-tune you'd be having a headache if the engineer know it's not 'standard', you may be up for expensive compliance process or re-exportation...
I know prices can't compete to back when A$ was over 90 JPY, but for $38k+ in my opinion at the end of the day you'll be a lot happier if you have a premium... just keep looking till the right one turn up.
I agree.
You will be surprised how cheap they are now though, even with the yen at only 72. A 6 speed white 03 model non premium went for less than 1.1m fob the other day, which is what, $22k landed and complied??
Anyway. I dont like my chances of another nismo kitted one popping up soon, so i may just end up with a random premium of some sort..
Thanks for the help :D
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
