this maybe a noob topic/question but ive got a r34, 4door 2000 model. im trying to put a cat back exhaust system but have come across a couple of problems:
1 - does any one know if a apexi catback exhaust system for r34 GTT ( 2door ) would fit on my
4door r34??
2- if the answer was NO to the previous question, then does anyone know where to get an exhaust system that would fit a r34 4door? ( a rep from autobarn told me that the only brand that the brand/comp that could make an exhaust for systems for 4door skylne was Greddy- somehow i dont think to be true)
ANYONE THAT HAS/HAD A R34 (4DOOR) AND FITTED A CATBACK EXHAUST SYSTEM PLEASE PM OR LEAVE A REPLY TO THIS TOPIC.
thanks heaps ppl.
tez
https://www.sau.com.au/forums/topic/265481-hey-all/
Alot of people use the coupe exhausts on sedans. Its just a matter of spacer being made up to go in one of the bolted joints, either before or just after the cat. I know on 33's its only about 20-50mm difference, depending on how far out of the rear bar you want the tip to sit.
https://www.sau.com.au/forums/topic/265481-hey-all/#findComment-4533886
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
