ive got a r34, 4door 2000 model. im trying to put a cat back exhaust system but have come across a couple of problems:
1 - does any one know if a apexi catback exhaust system for r34 GTT ( 2door ) would fit on my
4door r34??
2- if the answer was NO to the previous question, then does anyone know where to get an exhaust system that would fit a r34 4door?
ANYONE THAT HAS/HAD A R34 (4DOOR) AND FITTED A CATBACK EXHAUST SYSTEM PLEASE PM OR LEAVE A REPLY TO THIS TOPIC.
thanks heaps ppl.
tez
https://www.sau.com.au/forums/topic/265482-hey-all/
Fujisubo make a catback just for the 4 door N/A R34....but it is damn expensive! The cost of that system you can pretty much do your entire exhaust including extractors!
I've been told by many that the 2 door and 4 door catback are interchangeable, however in a thread not so long ago someone said the 4 door catback is longer...
Your main issue with aftermarket catback systems though is going to be the exhaust diameter. You reallly don't want anything bigger than 2.5" unless you're after top end power and willing to sacrifice low down power and torque. The majority of aftermarket systems are suited to turbocharged skylines and are 3" or larger in diameter.
Basically you will lose volumetric efficiency in the lower part of the power band with too large an exhaust as the exhaust gasses can't be scavenged and fill the exhaust as efficiently as it can with say a 2.5" system.
Of course the exhaust really depends on what other modifications you have done/plan to do (e.g. cams and cam gears, extractors)
You may find that getting a custom made exhaust from a reputable exhaust shop would be more cost effective and a lot better suited to your vehicle, plus they can design it to sit up higher under the car.
Anyways, that's a very quick run down on this topic, pretty much answers your question though. I felt the need to quickly outline the issue with exhaust diameter since you were obviously looking at aftermarket systems.
Hope that helps.
edit: If it helps, when I had my conversion done, my tuner said that a R34 GTT Coupe X-Force Catback would be fine for my Sedan. Another tuner in Brisbane confirmed for me that the 2 door catback will suit the 4 door, and that with some modifcation an R33 catback would also be suitable.
Edited by N-DAWG
https://www.sau.com.au/forums/topic/265482-hey-all/#findComment-4533722
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
