Sorry if im commandeering the thread
i have been reading around and getting some mixed views on this topic, what id like to know is, what is the raw output of a stock knock sensor, and what is the ecu looking for after the knock sensor is amplified?
so just in regard to the Knock amp/filter, they are bloody expensive, has anyone rigged up one from say...a jaycar kit?
any advice is much appreciated :D
Zurlox
mine is running off a jaycar kit but they are hardly compact.
The ecu is looking for a 0-5v input 0v being no knock and 5v being your engine about to explode with a signal somewhere in the region of 5-9khz.
any advice is much appreciated ;)
Zurlox
I looked into this a few months back. The knock sensor is basically a microphone. The amplifier just amplifies this so that it can be detected by the ECU. The problem is that the engine makes noise at all frequencies. We only need to detect the knock which occurs at specific frequencies. The frequency of knock depends on a few things. Bore size was one of them I believe. I found a formula somewhere that calculated the frequency for you.
So the external amplifier needs to amplify to right level and filter out any unwanted noise outside of the knock frequency. There is an IC out there that is designed specifically for this (I can look it up if you want). It is surface mount and not commonly available from shops like Jaycar.
Also, knock only occurs at a certain point in the engine cycle. Therefore, a smart amplifier/ECU will only switch on the knock sensor input at those points in the cycle where knock is expected. I'm not sure if the Vipec does this or not.
After reading all this I was thinking I'd go for the amplifier sold by Vipec/Bob, but then you need to induce pinging in your engine to set the gain correctly, etc. That kinda scares me, so I've stuck with no knock amplifier and trusted by tuner's tuning :D
  BoostedBarge said:
After reading all this I was thinking I'd go for the amplifier sold by Vipec/Bob, but then you need to induce pinging in your engine to set the gain correctly, etc. That kinda scares me, so I've stuck with no knock amplifier and trusted by tuner's tuning :laugh:
if your smart you can do it in a non detrimental way, obviuosly you dont want to induce knock at full load, full boost and so forth but it is simple enough to do it safely at the right time.
Edited by URAS
Zurloc PM'd me for further details on the knock amp, but I thought I'd reply here for the benefit of everyone else.
The knock amp IC is the TPIC8101 http://focus.ti.com/lit/ds/symlink/tpic8101.pdf
Autospeed article on DIY knock detection
http://autospeed.com/cms/title_DIY-Detonat...48/article.html
According to that article the frequency of knock can be approximated as 900/(3.14*Cyl Radius). I read somewhere else the frequency also depends on cylinder temperature and the location of the knock sensor, so I dunno how accurate that formula would be.
I was trying to find a Subaru site that I read a few months back. It had lots of info including sound recordings etc. Anyway, if you do a Google search you will find a mountain of information.
I wonder how different the knock amp settings will be from one engine to the next. Perhaps it would be good to collate everyone's settings in a database or maybe the Vipec forum. It would be awesome if we could say RB26 = frequency...., gain....
The stock ECU and the power FC must do the amplifying and filtering on board, so I guess engines must be fairly similar.
Zurloc: Keep us posted on how you go :down:
Edited by BoostedBarge
  • 1 month later...
Update:
i got the knock kit from jaycar, but the frequency band is wrong, it detects noise within 4.8Khz to 6.4Khz, which is too low, i am looking for a band of about 6.5Khz to 9Khz, so in order to achieve this i need to change a couple resistors. the one you change are the 2.7K resistor (inbetween the two 5.6K resistors top right of board) and i changed it to a 1.6K resistor to beef up the low pass filter, the other one you change is the 10K resistor (inbetween two 6.8nF caps top middle of board) and i changed it to a 12K resistor.
Now i havnt confirmed these changes but they should be pretty close :ermm:
Right from the horses mouth:
"Changing to the higher frequency range is easily done by changing the capacitor values in the filter.
The 6.8nF capacitors in the high pass filter become 5.6nF and the 3.3nF to 2.2nF and the 12nF to 10nF for the low pass filter."
This has come from the designers of the Jaycar Kit KC5444 to achieve a frequency band of 6-6.5Khz high pass to 8-8.5Khz low pass.
consult this diagram to get a better picture or things - Knock Schematic
Zurlox
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
