Hey guys just a few things i need.... does anyone have a spare right hand (GT) badge or a set.. also does any one have a full workshop manual for a r33 .. just had to replace a striped wheel stud and now the handbreak is kina soft.. thanx
theres a r33 service manual on pdf someone linked on ehere just the other day, ill see if i can find it
  • Replies 75
Hey guys.. just an update.. on monday gone i sent the car over to the painter to get the final paint done. They rang me today and said that the car and kit was all done. they just haft to do the handels and mirrors ect.. ill be picking up the kit on thusday and the car on friday. then the the other parts on monday..
since this is comming to an end and it will be all finished on monday.. iv started a new project
just going to clean up the boot and have a surge tank made. reason is that my current fuel pump (stock) is shitting it self when i go round corners.. so ill do it right the first time and have a bosch 040 intank feeding a 3ltr surge tank then have a bosch 044 feeding the fuel rail.. atm i will be using all new s/s braided lines and just connecting them to the old ones arround the fuel pump then later on when i get bigger injectors i will be able to run them all the way..
just a question i have painted matt black on the back of my car.. as you can see \/ \/ and wanting to know should i do this inside the boot, like have the full boot painted matt black or should i go gloss black or eaven the colour of my car... i would rather the matt as it looks great but havent seen ther other two so dont really know... can you guys help plz..
thanx
hey... got the car done and fitted the kit too... just waiting on getting the small parts back like door handels mirrors tail light covers and grill.. but i can drive the car now and its an enjoyment having driving it, but its not finnished yet.. hea are some pix
ideally you want a low pressure, high flow pump for your lift pump NOT a high pressure one like a bosch 040
Edited by Phobic
Nice work. Wondering if you got the indicators locally? Closest i got to that price is perfectrun.com.au but i'd rather buy here in Perth. Keep the progress updates coming.
Thx
you find them on ebay for 30 buks without postage.. not sure if their legit nismo though.
Thanx guys for ur comments ill be getting wheels soon probs before the new fuel pump and shit.. went looking today.. there are some nice volks arround the place...
if any one has any BLACK or Bronze colour with rubber with a 17 18 mabe a large offset so they fill the gards send me a pm please..
thanx guys
Good job mate
But where are your front indicators? There should have been some cut outs made for them. I used gtr indicators on mine.
I am sure you know this already but you need some new rims with a tuff offset. The stocks with a nice kit and paint job just dont cut it.
Hmm thanx pat yea I wired them too the park lights.. does the job and yea wheels are my next thing ay.. iv got some money to get shit ones but i want to find some jdm jap ones to go with the car..
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
