hey, sorry if iv been over posting
few days ago my car was making a strange squeking noise. not loud just so u can hear it at idle, didnt think much off it must of been a belt or suem...
then my car started to leak water not alot thoe ,
but yea i thought was air con or the wiper blade resivour thing coz i was out for a bust :S again i didnt think much off it..
i got my car back yesterday coz it was impounded ..... and on the free way it alomost over heated i let the car cool down and i toped it up and i got home sweet.. then temp neddle didnt rise past half way.....but im loosing water constanlty.
i had a look from "under" the car and its commin from the pump,. right behind the pulley theres a little hole and its just pouring out of there every time i top up, is it as simple as the wash plug fell out or som thing serios .ie internal seals or the pump it self is gone??
iv done 180 000km
and advice would be aprriciated :(
thanks
https://www.sau.com.au/forums/topic/265548-serios-water-leak-rb20det/
Usually when the little hole in the water pump shaft starts to leak, it's time for a new water pump.
The seal is stuffed and as a result the bearing is shot and that will be where the squeak is coming from.
thanks
i had another look, filled up the radiator again and blocked that hole, ur right the seal is gone :P
this all happend at the impound place so hopfully they pay for a new one
take care
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
