RB26 CAM WHEEL COVER ****SOLD******
If anyone is iterested in the remaining parts pm or call anytime onb 0400262578 in regards to any queries!!
Ps if you want to view the pics go to the 26 post and click on the link provided!!
  • Replies 58
Throttle bodies ****SOLD*****
NOT MUCH LEFT NOW!!!
R32 GTR ECU $100
INTAKE PLENUM(STOCK)$100
R32 STOCK TURBOS (EVERYTHING FROM EX MANIFOLDS TO DUMPS) $500 THE PAIR
OS GIKEN TWIN PLATE CLUTCH $600
R33 GTST CENTRE GRILL(WITH MESH) $60
R33 GTST N1 REPLICA FRONT BAR $150
I'M LOCATED IN ADELAIDE,SA. P&H ARRANGED AT BUYERS EXPENSE
ANYONE INTERESTED SEND US A PM OR CALL 0400262578
R32 GTR ECU $100
PLEASE NO LOW BALLERS! DONT NEED THE GRIEF!!!!
Hey guys,
the last few items that are remaining are:
-INTAKE PLENUM $100
-R32 GTR ECU $100
-STOCK R32 TURBOS $500 (LATE MODEL)
-STOCK 32GTR BOV'S $150
-RODS AND PISTONS $200 (NO DAMAGE TO ANY OF THE SIX)
-R33 GTST CENTRE GRILL $60
-R33 NI REPLICA FRONT BAR $150
IF ANYONE IS INTERESTED IN THE REMAINING PARTS, SEND US A PM
Hey guys,
-INTAKE PLENUM $100
-R32 GTR ECU $100
BUMP!!
BUMP!!
DUE TO INTAKE PIPING BEING SOLD NOW I ONLY HAVE THESE TWO PARTS OF THE INTAKE LEFT(PICS BELOW) + ALL THE OTHER REMAINING PARTS ASWELL AS A HARMONIC BALANCER.
HARMONIC BALANCER/CRANK PULLEY $80
TWIN BOV"s AND Y PIECE CERAMIC PIPE $100
CERAMIC PIPE JOINING TWIN TURBO SET UP $30
TOP QUALITY PARTS AT BARGAIN PRICES.
ANY INTERESTS/QUERIES SEND US A PM
RODS AND PISTONS SOLD***PENDING PAYMENT***(STYLZ7)
All pms sent.
ONLY A FEW THINGS LEFT!! GREAT TURBOS AT A EXCELLENT PRICE(CHEAPEST AROUND FOR THE PAIR)!
SEND US A PM IF INTERESTED.
  • 4 weeks later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
